02-17-2010, 18:36 | #1 (permalink) |
Insane Poster Join Date: Oct 2005 Age: 46
Member: 186515 Status: Offline Thanks Meter: 6 | Alcatel 363 unlock problem COM3 [VCP0] selected module v3.16 Device: Alcatel-363X, 363A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! baud autodetection active 9600 autodetect Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 2 sec Remove/Install battery now ! the phone is brand new and offcourse is working on orande France only!!! any sugestion is welcome!!! |
The Following User Says Thank You to globalmedia100 For This Useful Post: |
02-17-2010, 20:40 | #2 (permalink) | |
02-21-2010, 20:55 | #3 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 47
Member: 185608 Status: Offline Thanks Meter: 592 | Cable!Cable! Quote:
Check your cable and post result!!!! | |
02-22-2010, 08:02 | #4 (permalink) |
No Life Poster Join Date: May 2007 Location: IN {HUMEN}WORLD
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | plz help e221 virgin mobile sofware dead after flash only back light onn any solution to recover plz help infinity COM4 [Serial2] selected module v1.38 Device: Alcatel-E221 "advanced chip detection" active Action: flash write "smart write" active write: Firmware E221_firmware_U7CC_502.80M.bin skip: Flex/Customization write: Language Pack E221_lp_27O_905_En_Fr_It_xx_Ru.80P.bin skip: FFS/File system skip: Images skip: Melody write: Eeprom E221_repair_ffs_02.80E.bin Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20100222-113243.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 012A7E2A242A00:54000000000000 Write: Firmware Area: Language Pack flash: 012A7E2A242A00:54000000000000 Write: Language Pack Area: Eeprom flash: 012A7E2A242A00:54000000000000 Write: Eeprom Write done Finished, time used: 1 min 17 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to shakeel145 For This Useful Post: |
05-17-2010, 12:27 | #6 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Romania, Calarasi Age: 37
Member: 806633 Status: Offline Thanks Meter: 43 | ====> Boot ... Press and HOLD Power button now ! baud autodetection active 9600 autodetect Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 9 sec Remove/Install battery now ! i got this result with 5 different cables, tryed swaping rx with tx what did i do wrong ??? |
05-17-2010, 16:05 | #7 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum | |
05-24-2010, 10:30 | #8 (permalink) |
Freak Poster Join Date: Sep 2008 Location: peja KOSOVA Age: 46
Member: 856869 Status: Offline Sonork: +37744510000 Thanks Meter: 30 | unlock sucssesfull alcatel OT-363x with infinity COM9 [VCP0] selected module v3.29 Device: Alcatel-363X, 363A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B565:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.8CBF8 9D0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_94ABF0EB].rpl rom info detection finished device-id: 8CBF89D0 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, EBF0AB94 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI26CF30 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-363X,363A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__system_log_8CBF89D0_94ABF0EB_2010 0524-112412.B0X.bin Finished, time used: 2 min 51 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to kasim402 For This Useful Post: |
05-24-2010, 13:18 | #9 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Quote:
The Following User Says Thank You to kushol For This Useful Post: |
07-05-2010, 17:11 | #10 (permalink) | |
Freak Poster Join Date: Sep 2003 Location: Dominica Age: 59
Member: 39797 Status: Offline Thanks Meter: 13 | I found a phone with the same problem. Came from Orange France. I solved the problem by connecting the phone in a mirror image of what Infinity suggested. ORIGINAL INFINITY PINOUT Pin 1 B+ Pin 2 Ground Pin 3 Phone TX/ RJ45 pin 3 Pin 4 Phone RX/ RJ45 pin 2 Pin 5 Blank MY MODIFIED CONNECTION Pin 1 Blank Pin 2 Phone RX/ RJ45 pin 2 Pin 3Phone TX/ RJ45 pin 3 Pin 4 Ground Pin 5 B+ If anybody has a phone from Orange Fance with the same problem of not connecting, try my solution. Worked first try for me. Quote:
The Following 3 Users Say Thank You to j73wa For This Useful Post: |
10-22-2010, 12:44 | #12 (permalink) | |
Insane Poster Join Date: Mar 2005 Location: Zimbabwe
Member: 123140 Status: Offline Thanks Meter: 5 | Quote:
The Following User Says Thank You to yotamui For This Useful Post: |
OT-363 unlock problem | lucky_gsm | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 01-31-2010 16:43 |
Alcatel 512 Unlock Problem | toukour | SonyEricsson (USB-Smart) | 0 | 11-29-2005 06:16 |
Alcatel 512 unlock problem | usernome | SonyEricsson (USB-Smart) | 0 | 11-01-2005 12:05 |
Alcatel 512 Unlocking Problem | hamidtele | BF, BG, TH, BHx Series | 2 | 09-13-2003 08:11 |
alcatel 311after unlock problem .warning sos calls onlly HELP!!! | ssulkaa | BF, BG, TH, BHx Series | 1 | 09-26-2002 02:35 |
