04-27-2016, 10:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | Alcatel 4024D not detecting sim after unlock Code: Chinese Miracle II [SPD module] v 1.16 Start at : [27/04/2016 / 09:08:10] Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 92 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : 4024D Model Brand : TCL Model Device: PLAY_P1 AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA_18045 CompileDate : 15/01/2016 10:12:49 Project Ver : 4024D_D7_DZ_V1.2_160115 Model Ext : 4024D ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:27 Reconnect Power/Cable! Finish at : [27/04/2016 / 09:08:37] Read flash Code: Start at : [27/04/2016 / 09:09:26] Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 92 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 92 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : 4024D Model Brand : TCL Model Device: PLAY_P1 AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA_18045 Project Ver : 4024D_D7_DZ_V1.2_160115 Model Ext : 4024D [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc7731g_modem_CP2_WCN_14E_W15.42.5_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img AndroidInfo created Firmware Size : 1242 MiB Saved to : D:\Documents and Settings\GSM\Mes documents\SP7731GEA_18045_PLAY_P1_4.4.2_4024D_D7_DZ_V1.2_160115_4024D\ Done! Elapsed: 00:25:25 Reconnect Power/Cable! Finish at : [27/04/2016 / 09:34:52] BackupNV Code: Start at : [27/04/2016 / 09:36:20] Operation : Read NV [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 92 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read NVM Part #1 Part Ok Read NVM Part #2 Part Ok Saved to : D:\GSM\Alcatel\4024D\CX_SPDNV.spdnv Elapsed: 00:01:48 Reconnect Power/Cable! Finish at : [27/04/2016 / 09:38:08] Unlock Code: Start at : [27/04/2016 / 09:38:18] Operation : SP Unlock [ v1.16 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 92 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Locked! Unlocking ... Unlock Done! Elapsed: 00:00:46 Reconnect Power/Cable! Finish at : [27/04/2016 / 09:39:04] Imei ok basebande ok What's wrong ???? and how to fix ??? |
The Following User Says Thank You to temp_temp For This Useful Post: |
04-27-2016, 10:50 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. We already test such samples and they are completely Ok. Try make factory reset. If no luck - write NVM back and do factory reset again. It will bring phone to initial state. |
04-27-2016, 11:55 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | This flow bring phone back to locked state in any case. Are you sure about there is no any HW damage? Sim connector? Did you try other SIM? Does mobile ask something about code before unlock? |
04-27-2016, 16:56 | #7 (permalink) | |
Member: 570252 Status: Offline Thanks Meter: 207 | Quote:
04-27-2016, 17:17 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Thanks for info. I will upload unbranded FW and clean NV today/tomorrow on support and let you know, when it will be ready to download. Read FW from it now for further check cases ( probably - it will be need me , depending on unbranded FW flashing test ). |
