02-08-2015, 20:03 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | alcatel 4033x error Operation : Check / Read Info [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage Error : Correct DA sequence not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
02-10-2015, 07:42 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Preloader erased phones are not supported yet, team is working to add it. And Alcatel uses Secure Boot, so select SP: Autodetect Secure Emmc option in CPU in setting tab. Br. |
02-10-2015, 15:16 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Never. NEVER. NEVER SET SECURE mode, until CM2 not ask to try it. Alcatel SP not used secure mode, as far, as I know ( at least - not seen any yet ) If SW already re-installed , and you not have sometimes some error messages, like "Range Check Error" or something else - that is trange. If have - clean your reader , card and after re-install - try again. MT6571 , MT6572 FlashInit exists and allow boot phones with erased preloader. Most of current , unsupported adding in every update. 6582|6589 will follow soon. |
02-12-2015, 06:58 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, No need to use Secure mode until software asks to do so. Try Re-Install CM2MTK module and check again. Try to read firmware from another phone and write it to faulty phone. MT6571, MT6572 phones with erased preloader are mostly supported, so should work, as JayDi said in above post. Br. |
