07-21-2016, 10:38 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q mobile i1 Unknown structure detected Chinese Miracle II [SPD module] v 1.19 SLDR Load Ok BB CPU : SC7731 SC773x eMMc Loader v2.0 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [7/21/2016 / 2:22:15 PM] Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 204 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:12 Reconnect Power/Cable! Finish at : [7/21/2016 / 2:22:28 PM] Start at : [7/21/2016 / 2:23:01 PM] Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 204 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [7/21/2016 / 2:23:10 PM] Start at : [7/21/2016 / 2:23:33 PM] Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 204 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========================= 7/21/2016 / 2:30:18 PM ================================================== ======= Card found: S/N : 74A4D2CC , v0130 Chinese Miracle II [SPD module] v 1.19 SLDR Load Ok BB CPU : SC7731 SC7731 eMMC UMS 4G512M v2 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [7/21/2016 / 2:30:49 PM] Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 79 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========================= 7/21/2016 / 2:31:15 PM ================================================== ======= Card found: S/N : 74A4D2CC , v0130 Chinese Miracle II [SPD module] v 1.19 SLDR Load Ok BB CPU : SC773x SC773x eMMC v3.0 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [7/21/2016 / 2:32:08 PM] Operation : Format File System / Reset Settings [ v1.19 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 79 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v3.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:16 Reconnect Power/Cable! Finish at : [7/21/2016 / 2:32:25 PM] |
10-04-2018, 20:20 | #7 (permalink) |
Insane Poster Join Date: Nov 2009 Location: Cox's Bazar Age: 38
Member: 1166990 Status: Offline Thanks Meter: 7 | FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:12 plz help .....................me |
10-04-2018, 20:22 | #8 (permalink) |
Member: 1166990 Status: Offline Thanks Meter: 7 | ==== Wait for phone... Phone found! [ 32 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:12 Reconnect Power/Cable! |
10-05-2018, 13:17 | #9 (permalink) |
Freak Poster Join Date: Aug 2016 Location: Karachi (PAKISTAN)
Member: 2609063 Status: Offline Thanks Meter: 103 | Qmobile have lots of ANDA BACCHA... what you talking about ??? i2 ? i2 power ? i2 pro ? i have some logs of Qmobile i2 power below ... ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : i2_POWER Model Brand : QMobile Model Device: i2_POWER AndrVersion : 6.0 BaseBand CPU: SP7731CEA CompileDate : 11/28/2016 8:41:14 AM Project Ver : QMobile_i2_POWER_MP_08_11 Model Ext : QMobile i2 POWER ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:21 Reconnect Power/Cable! |
11-29-2018, 16:37 | #10 (permalink) |
Freak Poster Join Date: Oct 2015 Location: Pakistan Age: 36
Member: 2477331 Status: Offline Sonork: 100.1676088 Thanks Meter: 29 | Qmobile M88 After Flash Dead set is brand new not open problem is **** hot virus i flash writing 99% and software hang and not responding show the erer come and set dead now set detect but writing 1% stuck software and erer come charge batery hold key all u r method try but not writing flash not erase detect only writing problem i but same |
11-29-2018, 16:40 | #11 (permalink) |
Member: 2477331 Status: Offline Sonork: 100.1676088 Thanks Meter: 29 | Qmobile M88 Flashing problem Operation : Flash Erase [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 326 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Erasig flash now, please wait ... ERROR : FLASH_FULL_FORMAT failed! Reconnect Power/Cable! |
11-29-2018, 16:59 | #12 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
What is phone condition? Make FlashIC Test. Br. Infinity Box Team. | |
