02-19-2018, 11:50 | #1 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | Alcatel 4049D unlock ? How can I unlock this phone ? Code: Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
