05-22-2017, 14:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q mobile Z14 Main PMT update failed! ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D420717F0C2AC93FB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xD72A578BE10E95AEE78E36E594CE6DD6 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : gionee6755_66_m , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Main PMT update failed! Operation Failed Elapsed: 00:00:29 Reconnect Power/Cable! |
05-23-2017, 04:26 | #3 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Initial info read error! Erased or damaged FlashIC?! Force eMMC test by user request [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BM41X , 0x747C00000 , 29820 MiB [eMMC] : CID : 150100525831344D420717F0C2AC93FB [eMMC] : MODE : SQ-WR [FAILED] : Probably, something wrong with eMMC! Check cable and battery! Operation Failed Elapsed: 00:00:29 Reconnect Power/Cable! |
