05-04-2019, 18:54 | #1 (permalink) |
No Life Poster Join Date: Sep 2015 Location: SINDH, PAKISTAN.
Member: 2452939 Status: Offline Thanks Meter: 256 | Alcatel 5046i-2ATUAU1 Network locked Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! any chance to unlock it even using DA File ? |
05-04-2019, 18:56 | #2 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | Operation : SP Unlock [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : BOOTROM MODE : Alcatel : 5044 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_P.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
05-04-2019, 19:11 | #3 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | Operation : Identify (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device Info : Vendor : TCL Model : 5046I Device : 5046I Android : 6.0 Product : mickey6 Brand : TCL Serial : LJ4LP7FUSWU8IZZ9 Build_tm : Tue Nov 28 12:18:43 CST 2017 DisplayID : MRA58K release-keys Patch Ver : MRA58K SecPatch : 2017-10-05 Hardware : mt6735 MTK SVer : S01 MTK HVer : MT6737M MTK Prj : alps-mp-m0.mp1-V2.55.6_jhz6737t.65.mi.m0_P115 HW Board : MT6737 CPU rel : armeabi-v7a SIM Card : ABSENT BaseBand : MOLY.LR9.W1444.MD.LWTG.MP.V81.6.P42, 2017/11/28 12:15 BaseBand : MOLY.LR9.W1444.MD.LWTG.MP.V81.6.P42, 2017/11/28 12:15 RIL ver : mtk gemini ril 1.0 USB Conf : mtp,adb Sys USB : mtp,adb FS Crypt : encrypted Done! Elapsed: 00:00:06 |
05-05-2019, 10:33 | #7 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
05-05-2019, 10:53 | #8 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | Operation : SP Unlock [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM41) MODE : PRELOADER PORT PORT : 41 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : PRELOADER PORT MODE : Alcatel : A3 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_A3A_plus.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
05-09-2019, 16:52 | #10 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Do you hold volume down while connect the phone? ATM unlock should not be the 1st procedure, 1st of all make sure u find correct boot with the device before go to unlock process |
