01-07-2017, 17:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | alcatel 5054t not remove frp lock Card found : 94FBD840 , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.08 Operation : Reset Settings [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! also in identify tab only initilize show and software hang. |
01-08-2017, 10:17 | #3 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | alcatel pop onetouch 5054t frp remove successfuly-, it's my computer fault, thanks mr jaydi for reply- Card found : 94FBD840 , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.08 Operation : Reset Settings [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0400F760 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 659FF501AC3A27221D7282834C179FAF ID_BLOCK_L : DBAA14B7B82B9310B5005582806F7942 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
01-13-2017, 17:37 | #5 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
