Old 12-15-2009, 17:51   #1 (permalink)
Member: 364992
Thanks Meter: 28
alcatel 708 imei repair
Hello infinity team, i need to repair the imei of alcatel 708A,, i triend and then phone not power on.. only white screen 2 seconds and power off..
then i flashed phone with support 708a flash from movistar and phone alive again, then i unlock perfect, but cant repair imei.. the same error.. phone dead..
how can i repair imei of this phone.?
Old 12-15-2009, 19:07   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
please post logs of imei repair operations
Old 12-15-2009, 19:34   #3 (permalink)
Member: 364992
Thanks Meter: 28
log here:
Check your country laws before use this option !
In some countries this operation may be prohibited !
You must think serious before continue !
Do you understand above text well and want to continue ?
Imei 011XXXXXXXXXXXX already was repaired: 15/12/2009-12:15:53 p.m.
Continue with this imei ?
==== log: [15/12/2009 01:31:05 p.m.] ====
COM3 [VCP0] selected
module v2.99
Device: Alcatel-708X, 708A
Checking data, wait...
Action: "repair imei"
new imei: 0119XXXXXXXXXX
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:6B03:A009
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000003:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.1B CF2B31.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_A8667CC5].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 1BCF2B31
rom info protocol ver: 07
ver. sw 1: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
ver. sw 2: MAUI.08A.W08.40.SP1.V32, C57C66A8
code offset: 00020000
ffs offset/size: 01800000/00800000
TCL-ID identification
version: 16G
provider: 708A-2CTLGT3
customization: CN16NT24
customization: XN16NT24
TCL-ID identification done
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: disabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
original data found, method-A
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
sec info (fast) detection...
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
relocation table detected
name table detected
customization detected: SN16G050
customization: SN16G050
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
name table detected
done
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_1BCF2B31_A8667CC5_20 091215-133539.B0X.bin
Finished, time used: 272 sec
Remove/Install battery now !
Old 12-16-2009, 00:21   #4 (permalink)
Member: 364992
Thanks Meter: 28
please infinity box support i need a solution
Old 12-16-2009, 14:07   #5 (permalink)
Member: 364992
Thanks Meter: 28
support pleaseeeee need a responseee
Old 12-17-2009, 13:32   #6 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
write security backup back to mobile
Faisal_Computer
Old 12-17-2009, 15:56   #7 (permalink)
Member: 364992
Thanks Meter: 28
Old 12-17-2009, 21:15   #8 (permalink)
Member: 364992
Thanks Meter: 28
need a solution for imei repair please
Old 12-18-2009, 12:45   #9 (permalink)
Member: 151871
http://forum.gsmhosting.com/vbb/show...70&postcount=6
and post me results
Faisal_Computer
Old 12-26-2009, 17:27   #10 (permalink)
Member: 364992
Thanks Meter: 28
How to write security backup, where i need to select flashfile to write to phone ??? I select in firmware, customization and eprom and cant load the security file.
Old 12-26-2009, 17:37   #11 (permalink)
Member: 364992
Thanks Meter: 28
tried with 3.0 mmodule and still with the same error..
Old 12-27-2009, 07:37   #12 (permalink)
Member: 151871
hello,
what do you mean by can't load security file ?
which file you gave ? and post the log ?
Faisal_Computer
Old 12-27-2009, 13:49   #13 (permalink)
Member: 130995
Thanks Meter: 35,227
what is "same error" exactly ?
Old 12-27-2009, 15:14   #14 (permalink)
Member: 207651
How to write security backup, WHERE PLACE PLEASE
Old 12-28-2009, 10:20   #15 (permalink)
Member: 130995
Hello,
Security backup can be written by software automatically during flash write operation, you can not restore security backup manually due to this file contain many different data.
If you have any problems with phone you need just to flash it with nay firmware from support area and phone will be working.
alcatel 708 full flash plss ibrahim_casper Infinity-Box 1 03-28-2010 17:37
Need unlock Code for Alcatel 708 mrx3net Phone Unlocking Codes & Maps 1 03-13-2010 18:53
Problem Unlock Alcatel 708 and connecting [ANSWERED] cccdigital PolarBox 3 6 12-22-2009 17:59
It΄s Posible IMEI REPAIR in Alcatel 0.T 535?Ώ?Ώ Grupo MovilFree BF, BG, TH, BHx Series 1 07-21-2004 00:09
••• News again on GSM-BOX.net ! ••• Prodigy with IMEI repair ••• Alcatel Lurker Gold dani146 Main Sales Section 0 10-21-2003 21:34
Page generated in 0.23823 seconds with 9 queries
