08-20-2015, 21:17 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | ALCATEL AURUS III Flashing Error, Something wrong with HW or BL (FirmWare). It's ALCATEL AURUS III, Idea AURUS III, Megane_GSM. I Got With Hang At "Idea" Logo" & Try To Flash It. Operation Check Read Info [ v1.25 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info BB_CPU_ID 6575 BB_CPU_HW CB00 BB_CPU_SW 8B00 BB_CPU_SB E201 BB_CPU_NM [MediaTek] MT6575MT6577_S00 Processing BROM stage i2c Init 0300771F SpeedSet 0000 VChrgSet 0x28 , BatStat 0x02 WD Disable stat 0x0000 BLVersion 0x01 SecCfgVal 0x00000000 BromVersion 0xFF BLVersion 0x01 Preloader Status Alive Processing DA stage DA Select done , sending DA Stat v3.2 on BBID 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] FLASH_VEN 0090 , OEM 014A [eMMC] FLASH_INF HYNIX [eMMC] FLASH_CID 90014A2058494E594816A19173EF8095 [eMMC] FLASH_LEN 0x00000000E7000000 INT RAM 0x00020000 EXT RAM 0x20000000 BOOT TYPE EMMC_FLASH_BOOT SOC VERIFY C1 Boot Ok! [AP] Initial info read Ok! Brand TCT ProdName Megane ProdModel AURUS III Device Megane_GSM AndroidVer 4.1.1 MTKxCPU MT6577 MTKxPRJ ALPS.JB.MP.V1 Done! Elapsed 000013 Reconnect PowerCable! First Time I Read Factory Firmware In Hang At Idea Logo Condition & It's Give Error. Operation Read Flash [ v1.25 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info BB_CPU_ID 6575 BB_CPU_HW CB00 BB_CPU_SW 8B00 BB_CPU_SB E201 BB_CPU_NM [MediaTek] MT6575MT6577_S00 Processing BROM stage i2c Init 0300771F SpeedSet 0000 VChrgSet 0x28 , BatStat 0x02 WD Disable stat 0x0000 BLVersion 0x01 SecCfgVal 0x00000000 BromVersion 0xFF BLVersion 0x01 Preloader Status Alive Processing DA stage DA Select done , sending DA Stat v3.2 on BBID 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] FLASH_VEN 0090 , OEM 014A [eMMC] FLASH_INF HYNIX [eMMC] FLASH_CID 90014A2058494E594816A19173EF8095 [eMMC] FLASH_LEN 0x00000000E7000000 INT RAM 0x00020000 EXT RAM 0x20000000 BOOT TYPE EMMC_FLASH_BOOT SOC VERIFY C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU Skip Initial Info read [Image Ok] preloader_jrdsh77_cu_jb.bin [Image Ok] DSP_BL [Image Ok] MBR [Image Ok] EBR1 [Image Ok] lk.bin [Image Ok] boot.img [Image Ok] recovery.img [Image Ok] secro.img [Image Ok] logo.bin [Image Ok] custpack.img [Image Ok] system.img [Read Error] Bad EXT data Looks like unusable file , break! Read Ok , collect info Brand TCT ProdName Megane ProdModel AURUS III Device Megane_GSM AndroidVer 4.1.1 MTKxCPU MT6577 MTKxPRJ ALPS.JB.MP.V1 File conversion error, file already exists! Saved as default! Done! Elapsed 000929 Reconnect PowerCable! Factory Firmware Didn't Read Completely So I Leave That File & Flash With Other Firmware & Get This Error. (Other Mean I Read Factory Firmware From Working Cellphone). Operation Flash [ v1.25 ] Code: ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info BB_CPU_ID 6575 BB_CPU_HW CB00 BB_CPU_SW 8B00 BB_CPU_SB E201 BB_CPU_NM [MediaTek] MT6575MT6577_S00 Processing BROM stage i2c Init 0300771F SpeedSet 0000 VChrgSet 0x28 , BatStat 0x02 WD Disable stat 0x0000 BLVersion 0x01 SecCfgVal 0x00000000 BromVersion 0xFF BLVersion 0x01 Preloader Status Alive Processing DA stage DA Select done , sending DA Stat v3.2 on BBID 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] FLASH_VEN 0090 , OEM 014A [eMMC] FLASH_INF HYNIX [eMMC] FLASH_CID 90014A2058494E594816A19173EF8095 [eMMC] FLASH_LEN 0x00000000E7000000 INT RAM 0x00020000 EXT RAM 0x20000000 BOOT TYPE EMMC_FLASH_BOOT SOC VERIFY C1 Boot Ok! ScatCFG BaseBand MT6577 , Project MTK6577 , Storage eMMC Setting Flash Pre-Erase (Safe) Enabled Setting AFF verify Enabled BL Check HW compatibility BL BBID supported by BootLoader! BL Check eMMC compatibility BL eMMC supported by BootLoader! BL Flash Pre-Erase Total blocks to Erase 3 Erase 0x0000000001000000-0x0000000000008000 Erase 0x0000000001928000-0x00000000017C0000 Erase 0x00000000033E8000-0x00000000E1C18000 Flash Pre-Erase Done, time used 000011 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use preloader_jrdsh77_cu_jb.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount 0015 Update PMT by user request Repartition Failed! Break! Something wrong with HW or BL (FirmWare) Done! Elapsed 000029 Reconnect PowerCable! If Unchecked Repartition Operation : Flash [ v1.25 ] Code: ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A19173EF8095 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 3 Erase : 0x0000000001000000-0x0000000000008000 Erase : 0x0000000001928000-0x00000000017C0000 Erase : 0x00000000033E8000-0x00000000E1C18000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_jrdsh77_cu_jb.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Write Error! Something went wrong! Done! Elapsed: 00:08:54 Reconnect Power/Cable! |
08-21-2015, 10:15 | #4 (permalink) | |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote: Is It Scatter File ?. Like MT6577_Android_scatter_emmc Because I Have This Firmware SUGAR-MTK-AURUS-2XIJIN3-EE9-2013-08-06 Like, bin, output, tool, unins000.dat, unins000.exe. This File Only Can Use By Sugar MTK. & I Tried With it, It's Give Error. | |
08-21-2015, 11:45 | #5 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
tested | |
08-21-2015, 16:11 | #6 (permalink) | |
Error In SPFT : Unrecognized ROM detected. Dear Friend, Same Error With This File. Chinese Miracle II [MTK module] v 1.25 Code: Scatter Load Ok , BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.25 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A19173EF8095 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 3 Erase : 0x0000000001000000-0x0000000000008000 Erase : 0x0000000001928000-0x00000000017C0000 Erase : 0x00000000033E8000-0x0000000047B00000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Failed! Break! Something wrong with HW or BL (FirmWare) Done! Elapsed: 00:00:24 Reconnect Power/Cable! | |
10-26-2015, 12:03 | #9 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: DHARAMPUR<GUJRAT>INDIA
Member: 646646 Status: Offline Sonork: 100.1664464 Thanks Meter: 240 | i am try idea arus 3 file full flash but blue screen after idea logo pls give me solution sir ji Quote:
