08-15-2009, 14:50 | #1 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | Alcatel C363, dead after Flash, InfiniTeam pls I want unlock a small Alcatel OT-363, and after flash it with this file : 363X-2AALCN1-230_XI23BJ00_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V9_2009-03-05_En_CnS_CnT_simfree.B0M , the phone don't power on, I format FFS and same, I flash it with this now : 363X-2ARGES1-267_XI26CE21_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V9_2009-05-22_En_Es_Galician_Basque_Catalan.B0M and same can't power it, I wait on power button 2 min, for information the software tell me it's a new version, and I ignore this message same on many phone and continue and flash it. if I find the same phone, can read the full flash and write it on this one for reviver it ? Best Regards, JAVA Good. |
The Following 3 Users Say Thank You to JAVA Good For This Useful Post: |
08-15-2009, 21:06 | #4 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | TKS for you reply, I have the latest one v2.83, now my phone is dead, I think this 2 or 3 days I buy same one for my customer and for more test and read full flash and send it for you, and it's possible to read the flash for new one and write it on my old one ?, can I reviver it like this ? Best Regards, JAVA Good. |
08-15-2009, 21:15 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Are you sure that phone battery was enough charged ? Do you see any errors during flash process ? Did you tried to use "Repair security area" button ? |
08-15-2009, 21:31 | #7 (permalink) | |
Member: 66136 Status: Offline Thanks Meter: 200 | @InfinitySupport I use a power supply from USB cable, don't use battery, and for sure I use an other battery from other Alcatel work good, I haven't anny error on flasing, there is the log : Quote:
tomorow I flash it again and enable Format FFS during write. Best Regards, JAVA Good. | |
08-15-2009, 21:32 | #8 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | hoooo sorry I forget, on second flash I have this error : error: boot initialization step #3 failed: 00 but on first flash no probleme. BR. |
The Following User Says Thank You to JAVA Good For This Useful Post: |
08-16-2009, 08:56 | #10 (permalink) | ||
Member: 66136 Status: Offline Thanks Meter: 200 | I am sorry, because verry tired, the second flash : Quote:
Best Regards, JAVA Good. | ||
08-16-2009, 10:46 | #11 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: Setif ALGERIA Age: 44
Member: 80990 Status: Offline Sonork: 100.1583974 Thanks Meter: 312 | Quote:
COM3 [VCP0] selected module v2.83 Device: Alcatel-363X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware 363X-2AALCN1-230_XI23BJ00_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V9_2009-03-05_En_CnS_CnT_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AE03:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.57D73 F61.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_92EE7E58].rpl ==================== New firmware detected (v.2.83, database date: unknown): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 57D73F61 identification#1 protocol ver: 05 ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V9, A781116D ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done Write ... security area (code #1) check... security area (code #1) calculation... security area (code #1) fixed file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9__system_log_57D73F61_92EE7E58_20090816-102203.B0X.bin Area: Firmware flash: 98000300000001:2BEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CI23BJ00 done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... error: security area (code #3, part #1) size is incorrect: 01C0 instead of 0374 Write Done Finalization ... formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9__system_log_57D73F61_92EE7E58_20090816-103303.B0X.bin Finished, time used: 702 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! But my problem is solved after repairing securiry area : COM3 [VCP0] selected module v2.83 Device: Alcatel-363X Checking data, wait... advanced flash detection enabled Action: repair security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AE03:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.57D73 F61.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_81A324EB].rpl identification#1 detection finished device-id: 57D73F61 identification#1 protocol ver: 05 ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V9, 14DB5C7E ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 security area (code #1) check... security area (code #1) fixed detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled security area (code #3, part #2) calculation... customization: CI23BJ00 done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000001:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9__system_log_57D73F61_81A324EB_20090816-103833.B0X.bin Finished, time used: 149 sec Remove/Install battery now ! | |
The Following User Says Thank You to GSMSERVE For This Useful Post: |
08-16-2009, 16:29 | #12 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | hello and tks for your reply, I go on repair section and "Repair security area", now phone work fine, but not unlocked, I flash it again with simfree file, and phone work good, but only english and 2 chines language, anny solution for other language pls like a french ? Best Regards, JAVA Good. |
08-17-2009, 06:57 | #14 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | tell me pls InfinitySupport, if I find new one, can I read the full flash if it's a new version and send it for you ? what is time for update pls ? and I see some other box can unlock it, if I find this flash files, can I flash my phone with this files ? because don't the time and need get back this phone for my customer. Best Regards, JAVA Good. |
08-17-2009, 08:42 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, We need to get flash file from simfree phone (not phone unlocked by code but from phone that was originally simfree). If you have full flash backup from this kind of phone please send full flash backup to [email protected] |
Alcatel E805X dead after flashing | yotamui | Alcatel TCL Phones and New Models | 12 | 07-23-2008 18:29 |
alcatel c701x dead after flash in infinity box | .::ricky rayya::. | Infinity-Box | 21 | 04-09-2008 10:24 |
Alcatel OT152 Dead after flashed | my7010107 | Infinity-Box | 11 | 12-17-2007 16:54 |
alcatel E259x dead after flashing!!!. plz help | abumu3ed | FuriousGold | 3 | 07-07-2007 13:23 |
alcatel bg31g dead after flashing | skorn | BF, BG, TH, BHx Series | 5 | 07-05-2005 07:48 |
