Old 07-16-2008, 11:50   #1 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Sigmatel S1 Still Dead??????????
SIGMATEL S1 STELL DEAD AFTER FULLFLASH THIS IS LOG----
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:6203:0001
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18A59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080716-124234.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 139 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
IFLASH THE PHONE THIS VIRSION:- GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S1-ML_MR106_006_5S01-MC-C01-RF3198_V1_0_017_080226_Sigmatel-S1_En_Fr_Vn_Ru_Ar_Th.B0M.bin
AND MY BACKUP FULLFLASH IS:-flash_20080716-120203.B0M
PLESE HELF.
Old 07-16-2008, 11:54   #2 (permalink)
Member: 484872
Thanks Meter: 108
100% solved
please reading firmware and eprom good sigmatel s1 model then write
Old 07-16-2008, 12:29   #3 (permalink)
Cheater -Don't Deal with him-
mobilecraker's Avatar
Member: 142219
Sonork: 100.107814,
Thanks Meter: 368
Action: reset
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize...
Initialize Done
Set baud...
460800
Set baud Done
.damaged firmware
.damaged hardware
ffs chip: 00
reading [eeprom]...
Write...
Write Done
Finalization...
formatting...
Finalization Done
PLESE HELF.
why you flash this handset,why not try first formate safe or complete?
br
mobilecraker
Old 07-16-2008, 15:49   #4 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
br
mobilecraker
i format allrady, no result, then i flash phone in this virsion:-
can anather idea plese tell.
Old 07-16-2008, 15:52   #5 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
no friend ,no other phone at this time. can you sand 100% readed file
at this email:[email protected]
Old 07-16-2008, 16:19   #6 (permalink)
Member: 142219
Sonork: 100.107814,
Thanks Meter: 368
the flash file you is ok n fine for this mobile,resold flash ,cpu n surrounding components with flex n hot air station
Old 07-16-2008, 16:19   #7 (permalink)
luqmaan751's Avatar
Member: 416940
Thanks Meter: 173
i also having same problem flashing is ok but phone is not getting on then i disassemble the phone and given slight hit on the ic.
problem is solve .just try ur luck bro.........
Old 07-16-2008, 19:18   #8 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
i also try this ,but no result. can anybody sand epprom file? or reded flash file?
Old 07-16-2008, 20:07   #9 (permalink)
Member: 148515
Thanks Meter: 19,534
hello mr. mov009!
Did you read full backup befroe flashing with that file?
or eeprom backup is the only thing which you have?
Old 07-16-2008, 22:25   #10 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
hello mr. mov009!
no sir phone allrady flash other place, so sir i don't know what is right file can you helf sir right flash file?
this is phone sir-
Old 07-17-2008, 10:16   #11 (permalink)
Member: 148515
hello!
send me eeprom backup to [email protected]
i will look inside maybe will find what version it was
Old 07-17-2008, 13:04   #12 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
can anybody helf plese
can anybody helf plese, or sand file plese, iam so tryed,
Old 07-17-2008, 15:34   #13 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
hello!
ok sir i am sand this file in this adderess,
Old 07-17-2008, 23:05   #14 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
no body have hear? for helf me?
infinity team plese helf what is right file in this set.
Old 07-18-2008, 11:46   #15 (permalink)
Member: 148515
hello!
i asked you to send me eeprom backup "eeprom_20080716-124234.B0E.bin"
but you sent me full flash. please find mentioned above eeprom backup and send it to me
sigmatel s1 dead plz help subra007 Infinity-Box 4 03-09-2009 12:32
sigmatel s1 dead after flash bhogpurmail Infinity-Box 18 09-22-2008 18:40
sigmatel s1 dead by format jitugrover SpiderMan 5 09-21-2008 14:34
sigmatel s1 dead jitugrover Chinese Models & Cloned Phones 2 08-08-2008 12:24
sigmatel s1 file not found at support area SAHEB Infinity-Box 1 05-26-2008 17:55
Page generated in 0.27191 seconds with 10 queries
