Old 10-15-2008, 21:26   #1 (permalink)
Member: 210672
Sonork: 1586124
Thanks Meter: 35
Exclamation Alcatel C700a, Unlock: how to?
Hi.
I try flashing with flash simfree from support, flash without error.
But the cellphone always restart when trying to power on.
Test with format and IxxI repair.
Any solution Pleasy.
PD: Work ok with Alcatel C701a.
Old 10-15-2008, 21:42   #2 (permalink)
Service4Gsm.de's Avatar
Member: 811992
Sonork: 100.1584257
Thanks Meter: 162
Hello
Which errors indication did you get with infinity? Then write also times which there.
Old 10-15-2008, 21:59   #3 (permalink)
Member: 210672
Sonork: 1586124
Thanks Meter: 35
No errors show, flash ok. But when I try to power on (holding the power button) the phone show startup logo and power off.
Then try format or FFS erase, etc... and same problem, phone alweys restart.
__________________________________________________ ________________
COM12 [VCP0] selected
Device: Alcatel-OT-C700A
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
enhanced security fix enabled
Boot...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing[6226:8A03:8A02]...
CPU: MT6226
chip: 0031:E4C6:A000
high speed disabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22312200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Celular\InfinityBox\MModule\backup_security\id. 018D9375.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_70B772E8].rpl
identification#1 detection finished
device-id: 018D9375
identification#1 protocol ver: 05
ver. sw1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN
ver. sw2: MAUI.06A.W06.52.SP1.V24, 178D488F
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
sim-lock status: disabled
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
original imei: 01129000108850
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
security area (code #1) calculation...
done
file saved: C:\Celular\InfinityBox\MModule\backup_security\sys tem_log_018D9375_JRD26_06A_PCB01_GPRS_MT6226_S02.M AUI_06A_W06_52_SP1_V24.BIN_70B772E8_20081015-165326.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CD34GF01
customization area adjusted: CD34GF01
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
..................counter: 01
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Celular\InfinityBox\MModule\backup_security\sys tem_log_018D9375_JRD26_06A_PCB01_GPRS_MT6226_S02.M AUI_06A_W06_52_SP1_V24.BIN_70B772E8_20081015-165555.B0X.bin
Finished, time used: 193 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Escuse my english.
Old 10-15-2008, 22:00   #4 (permalink)
Masud-GSM's Avatar
Member: 396988
Sonork: 100.1613227
Thanks Meter: 179
try to flash the phone any other flash file..................
Masud
Old 10-15-2008, 22:15   #5 (permalink)
Member: 210672
Sonork: 1586124
Thanks Meter: 35
Try with all the simfree flash, always the phone restart.
But with the another flash (no simfree) the cellphone power up work well, locked off course.
Flashes unlocked are bad, or the metod is wrong?
Thanks and Escuse my english.
Old 10-15-2008, 22:24   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,071
Hello,
simfree files was uploaded today. It\'s need to use latest software with this files.
Updated software for test will be released in several hours, I\'ll post link here and we will see results.
Old 10-15-2008, 22:28   #7 (permalink)
Member: 130995
Hello,
Here is link to new software: http://www.infinity-box.biz/download...dule_v2.36.rar
Please, flash phone and be sure that "enhanced security fix method" option in "Settings" page is DISABLED (not checked) !
Old 10-15-2008, 22:31   #8 (permalink)
Member: 210672
Sonork: 1586124
Thanks Meter: 35
THZ, testing now.
Very good support....
Old 10-16-2008, 00:58   #9 (permalink)
Member: 210672
Sonork: 1586124
Thanks Meter: 35
Tested.
infinity-box, full support Alcatel C700a (unlock and IxxI repair.
Good work bro.
______________
Otro porotito para infinity, C701 y C702 full.
The Following User Says Thank You to elpocitano For This Useful Post:
Old 10-16-2008, 01:25   #10 (permalink)
Member: 210672
Sonork: 1586124
Thanks Meter: 35
Originally Posted by elpocitano View Post
Tested.
Good work bro.
______________
Perdon
Otro porotito para infinity, C700 y C701 full.[/quote]
Old 10-16-2008, 08:44   #11 (permalink)
Member: 130995
Hello,
Thanks a lot for test report !
Please, if you still have phone, tests it carefully, try to insert other sim card and power-on/power-off phone several times.
I think everything should be Ok, but anyway, any additional test is welcome.
Old 11-01-2008, 21:36   #12 (permalink)
Member: 210672
Sonork: 1586124
Thanks Meter: 35
After tested many Alcatel C700a, latinamerican version, from CTI.:
The more stable flash for unlock, from support is:
C700A-2ACBAR1_XD34GD04_JRD26_06A_PCB01_GPRS_MT6226_S02.M AUI_06A_W06_52_SP1_V24_2008-02-01_En_Fr_Es_Pt-BR_It_simfree.B0M.bin
Try and report, thz.
Old 11-02-2008, 03:17   #13 (permalink)
Member: 614097
Thanks Meter: 24
use infinity box & m module2.38 & after flash format ffs area phone 100% working & read this precautions
Date: 02 Feb 2008
How to unlock and flash Alcatel-c700, c701, c707, c717, c825 etc.
How to flash:
1. Make full flash backup before any operation for emergency case !
2. Select firmware that you want and write flash
3. If phone can't power-on after flashing flash it again:
. be sure that "Smart write option is checked in "Flash" page
. be sure that "Fix security area" option is checked in "Settings" page
. be sure that "Enhanced security fix method" option is checked in "Settings" page
4. If phone can't Power-On make "Format ffs" in "complete" mode
5. Press and hold phone "Power" button for a long time (up to 1-2 min) to make phone Powered-On after flash/format
After flash process: Power-On and Power-Off phone 4-5 times to be sure that everything is Ok.
If software say that new firmware detected please make this:
1. read full flash
2. send "backup_flash..." and "backup_system_log..." files to [email protected] or upload to rapidshare.com and send link
How to unlock:
1. Flash phone with non-locked firmware
The Following User Says Thank You to hajipur For This Useful Post:
Old 11-05-2008, 20:01   #14 (permalink)
Member: 74338
Thanks Meter: 11
Originally Posted by InfinitySupport View Post
Hello,
does these solution apply to c825 model too? my problem has been to establish connection with the phone. i have to do many phones with infinity box without any problem but this one Alcatel C825 has been a headache to me.
the flashing is done via USB CABLE or on the test point position on the phone. i have done the testpoint for Alcatel c701 but no success. i have bothered all my infinity users with this problem so very much. please bear with me just trying to get the phone done for my client which i have promised that only INFINITY BOX can do it.
very many thanks in advance for your positive response.
cheers
Old 11-05-2008, 20:53   #15 (permalink)
Member: 130995
Hello,
Just make Rx/Tx cable according to instruction from Shell.
Here is information how to build your own cable: http:///vbb/showthread.php?t=342807
ALCATEL OT-557 how to flash with infinity ?? grahacenter Infinity-Box 3 10-03-2007 17:08
Alcatel OT 525 How To unlock SoftSkiner BF, BG, TH, BHx Series 1 11-17-2002 19:38
alcatel be3 166 how to GURO Alcatel & TCL Old Models 2 12-26-2001 17:22
Hi friend! Alcatel HE1 v300 - How to unlock -? mobydick Alcatel & TCL Old Models 3 12-25-2001 12:11
Page generated in 0.44705 seconds with 8 queries
