03-12-2010, 14:54 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Colombia Age: 48
Member: 197360 Status: Offline Thanks Meter: 25 | alcatel c701a still locked after unlock and flash it with a simfree flash it still locked. all process succes ok: unlock and flashing "invalid sim", only reads original sim. help! |
03-12-2010, 15:28 | #3 (permalink) | |
Member: 197360 Status: Offline Thanks Meter: 25 | Quote:
thanks for your answer, you are the best! i'm realy happy with this box. i bay it two months ago and it's very usefull. i have last version but nothing... what other solution can i try? | |
03-12-2010, 16:40 | #5 (permalink) |
Member: 197360 Status: Offline Thanks Meter: 25 | i flashed with another version flash from support, COM3 [VCP1] selected modulo v3.25 Servicio: Alcatel-C701X, C701A Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: write flash "smart write" activado "formateo de ffs" activo Escribir Firmware C701A-2ACECO1_XC19NG26_JRD26_06A_PCB01_GPRS_MT6226_S02.M AUI_06A_W06_52_SP1_V24_2007-08-10_Comcel-Colombia_En_Fr_Es_Pt-BR_It.B0M.bin saltar: Customization/Language Pack saltar: Customization saltar: Eeprom/ffs ====> Boot ... Mantenga Presionado el boton Power ! baud autodetection active 19200 autodetect Conectando, espere... Iniciando [6226:8A03:8A02]... CPU: MT6226 chip: 0031454:A000 status: 01 alta velocidad de boot Off Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E22302200:2BEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 115200 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.85 AC9AB6.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_AACB2F63].rpl rom info detection finished device-id: 85AC9AB6 rom info ver: 05 sw version: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN project-id: MAUI.06A.W06.52.SP1.V24, 632FCBAA code offset: 00000000 ffs offset/size [01]: 01200000/00E00000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01200000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished Estado sim-lock: disabled product id: JRD_Communication_Inc_C7_Series area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Imei original: 01107300852345 Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #1)... not required Operacion Especial Done ====> Escribir ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-C701X,C701A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24__system_log_85AC9AB6_AACB2F63_20 100312-094452.B0X.bin Area: Firmware Flash 01227E22302200:2BEA0000000000 Escribir Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected Personalización CC19NG26 customization name adjusted customization detected: CC19NG26 Personalización CC19NG26 Flash 01227E22302200:2BEA0000000000 Flash 01227E22302200:2BEA0000000000 Escribir security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 01227E22302200:2BEA0000000000 Flash 01227E22302200:2BEA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done Escribir Done ====> Finalizado ... FFS formatting... Flash 01227E22302200:2BEA0000000000 Finalizado Done Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-C701X,C701A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24__system_log_85AC9AB6_AACB2F63_20 100312-101822.B0X.bin Finalizado, tiempo usado: 34 min 46 sec Quite/coloque la bateria ahora ! i turned on phone and it asked for subsidy code reconect for unlock process and it happened(see pic), Why????? i tryed again and this is the result: COM3 [VCP1] selected modulo v3.25 Servicio: Alcatel-C701X, C701A Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: rebuild security area ====> Boot ... Mantenga Presionado el boton Power ! baud autodetection active 19200 autodetect Conectando, espere... Iniciando [6226:8A03:8A02]... CPU: MT6226 chip: 0031454:A000 status: 01 alta velocidad de boot Off Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E22302200:2BEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 115200 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.85 AC9AB6.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_5725BEE3].rpl rom info detection finished device-id: 85AC9AB6 rom info ver: 05 sw version: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN project-id: MAUI.06A.W06.52.SP1.V24, E3BE2557 code offset: 00000000 ffs offset/size [01]: 01200000/00E00000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01200000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished Estado sim-lock: enabled product id: JRD_Communication_Inc_C7_Series area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected Personalización XC19NG26 customization name adjusted Flash 01227E22302200:2BEA0000000000 Flash 01227E22302200:2BEA0000000000 Escribir security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 01227E22302200:2BEA0000000000 Flash 01227E22302200:2BEA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Imei original: 01107300852345 Flash 01227E22302200:2BEA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Escribir Done ====> Finalizado ... FFS formatting... Flash 01227E22302200:2BEA0000000000 Finalizado Done Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-C701X,C701A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24__system_log_85AC9AB6_5725BEE3_20 100312-103205.B0X.bin Finalizado, tiempo usado: 4 min 36 sec Quite/coloque la bateria ahora ! it still locked |
03-14-2010, 19:34 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Are you sure that phone is still locked ? Are you able to enter into phone menu with any sim card ? What text you see at phone LCD when you power-on phone with sim card ? |
help problem after flash alcatel c701a movistar mexico | ramscell | Infinity-Box | 3 | 12-02-2008 18:37 |
alcatel c701a pinout problem help me | negocionet | Infinity-Box | 1 | 09-07-2008 23:55 |
solution for equipment or mt6226 alcatel c701a and c717a | crowys | HWK | 0 | 08-19-2008 16:07 |
When unlock Alcatel c701a. | crowys | Infinity-Box | 16 | 08-06-2008 12:39 |
what is flashing adapted to release alcatel c701a | joseudi | Infinity-Box | 4 | 07-03-2008 00:09 |
