Old 07-03-2009, 07:54   #1 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
n95 china after flash white lcd
please for help im flash n95 china with 2 sim
use flash file from suport area after flash phone working bbut lcd is the white
what is solutions
COM4 [VCP0] selected
module v2.84
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:6603:0003
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
slowest
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN
ver. sw 2: MAUI.GEMINI.W08.12, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 38 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to delchoni For This Useful Post:
Old 07-03-2009, 08:29   #2 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
that's mean you didn't use the right firmware!
Old 07-03-2009, 09:08   #3 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
thanks for support now lcd is okk
but phone send file wia bluetoth but cant recivied data from other phone
phone set write file failed
Old 07-03-2009, 09:26   #4 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
all is done all time success with infinity
Old 10-22-2009, 09:34   #5 (permalink)
Member: 461923
Thanks Meter: 2,020
hello..i have one n95_8gb with white screen..
..please anybody can tell me which file is good for my phone ??
n95_8gb Type : RH-84
IC:661Z-RM159
code 0539266
CPU : MT6226BA
..this is PCB :
The Following User Says Thank You to stefani For This Useful Post:
Old 10-22-2009, 17:40   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
IC:661Z-RM159
code 0539266
CPU : MT6226BA
..this is PCB :
hello!
make "read detailed information" and post required frimware version
Old 10-23-2009, 07:18   #7 (permalink)
Member: 461923
Thanks Meter: 2,020
hello!
COM3 [VCP1] selected
module v2.73
Action: read/check detailed information
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:0B41:6C3C
high speed boot Off
boot packet size: 0002
Boot Done
Initialize ...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
921600
Set baud Done
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.7DFA6BDB.[N95_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_F2.BIN_5 7250030].rpl
device-id: 7DFA6BDB
ver. sw 1: N95_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_F2.BIN
ver. sw 2: MAUI.05C.W06.16.F2, CFFFDAA8
ffs offset/size: 00D00000/00300000
warning: optional information is not found,
if phone works well just ignore this warning
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00D00000
eeprom/ffs found near: 00D00000
detecting eeprom/ffs size...
eeprom/ffs size: 00300000
ffs chip: 00
eeprom/ffs area: 00000000:00D00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs detected ok: element #1
detecting ffs structure pass 2...
ffs detected ok element #2
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_7DFA6BDB_N95_PCB01_GPRS_MT6226_S01.MAUI_ 05C_W06_16_F2.BIN_57250030_20091023-085928.B0X.bin
Finished, time used: 255 sec
Old 10-23-2009, 08:12   #8 (permalink)
Member: 461923
Thanks Meter: 2,020
hello!
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: Kongli26_06B_HW
Old 10-23-2009, 23:18   #9 (permalink)
Member: 148515
hello!
we have 8 flash files on support.
worth to try them.
each time power On phone and check if this helped or not
support area search example:
http://forum.gsmhosting.com/vbb/showthread.php?t=499453
Old 11-06-2009, 09:24   #10 (permalink)
Member: 461923
Thanks Meter: 2,020
hello!
worth to try them.
..hello..after write all flashes from support..nothing hapend..
..but all ok after write flash saved from a good phone..
..this is flash...maybe help somebody..
http://rapidshare.com/files/30308588...94636.B0M.html
Old 11-08-2009, 20:24   #11 (permalink)
Member: 148515
hello!
i will upload this firmware to our support site, keeping EEPROM area
Old 03-19-2010, 23:39   #12 (permalink)
Member: 1265836
how can i apply this to my phone?
my phone has the same problem,how can i apply it, i dont know how...please send me remedies.
Old 03-20-2010, 10:32   #13 (permalink)
Member: 148515
hello!
try different firmware from suppoort area
Old 10-23-2010, 18:02   #14 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 561
i have a same probleme plz wish firmware did you slove your probleme ?
Old 10-24-2010, 19:51   #15 (permalink)
Member: 148515
hello!
please explane which problem you have and what is your phone original software version
chaina nokia 1650 after flashing white lcd plz help guljee786 Chinese Models & Cloned Phones 4 08-16-2009 16:40
nokia 6300 china after flash white screen sjni Infinity-Box 1 07-05-2009 20:31
N95-8gb China after flashing no Display topnoyze Infinity-Box 4 10-07-2008 20:55
Page generated in 0.26861 seconds with 11 queries
