07-02-2009, 17:18 | #1 (permalink) |
No Life Poster Join Date: May 2005
Member: 148833 Status: Offline Thanks Meter: 25 | Alcatel E221:No Remove of user/phone/lock code & No accept to be flashed Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20090702-165728.80E.bin Read data done Check data ... Check data done Write ... Area: Eeprom error: no any expected answer error: no any expected answer : wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer : wrong answer after chip cfi request error: no any expected answer error: no any expected answer : wrong answer after chip id request Write fail error: operation failed Finished, time used: 107 sec Remove/Install battery now ! An d now watch the log when try to flash it with the same firmware of orange from support :COM3 [VCP0] selected module v1.34 Device: Alcatel-E221 "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20090702-171441.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 012A7E2A242A00:54000000000000 Write: Firmware error: no any expected answer error: flash write error: 06006000:00002000 error: no any expected answer error: flash write error: 06006000:00002000 error: no any expected answer error: flash write error: 06006000:00002000 error: no any expected answer error: flash write error: 06006000:00002000 error: no any expected answer error: flash write error: 06006000:00002000 Write fail error: operation failed Finished, time used: 163 sec Remove/Install battery now ! |
07-04-2009, 05:01 | #4 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 914747 Status: Offline Thanks Meter: 22 | if u want to remove user code then ###847# and do the factry setting nd if u got flashing error make sure use fully charged bettery and post result |
The Following User Says Thank You to AY29!4LYF For This Useful Post: |
How To Remove Phone Lock Code Of k550i ? | Tajammul | SETool2 | 5 | 07-15-2011 03:47 |
Cannot remove SE Z750 phone lock code? | svchost | SETool2 | 2 | 10-01-2009 11:57 |
W350i Phone lock code can't be remove? | denard | Cruiser Suite | 3 | 07-14-2009 08:14 |
philips -192 user phone lock code errror !!! | fener1 | Infinity-Box | 1 | 05-15-2009 14:35 |
