02-09-2009, 13:21 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: +92 345 5313170
Member: 802214 Status: Offline Sonork: 100.1573572 Thanks Meter: 95 | Alcatel-E227 unlock 100% COM9 [VCP0] selected module v1.30 Device: Alcatel-E227 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E227_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20090209-171734.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 96 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to .::adnangsm::. For This Useful Post: |
02-10-2009, 22:28 | #4 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
Alcatel E227 Unlock successfully | Kanwalgee | Infinity-Box | 11 | 10-20-2015 19:26 |
ALCATEL E227 unlock successfull!!! | mak_14344 | Infinity-Box | 6 | 07-03-2010 18:02 |
Alcatel-E227 unlock ok by infinity | aleem26 | Infinity-Box | 1 | 11-05-2008 18:58 |
Alcatel E227 unlock fail | celluniversal | Infinity-Box | 1 | 08-29-2008 12:15 |
Alcatel E227 unlock ?? | gsmline | Easy-Unlocker | 6 | 06-10-2008 21:00 |
