11-24-2016, 10:25 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | Lenova a6000 read done but write fail... Code: Operation : Read Flash [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0DB43911 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E6B4B98A0 ID_BLOCK_L : C060A78CC318A96C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : Lenovo ProdName : Kraft-A6000 ProdModel : Lenovo A6000 Device : Kraft-A6000 AndroidVer: 5.0.2 Manufact. : LENOVO QLMxCPU : MSM8916 DevInfo : MSM8916__LENOVO__Lenovo__ANDR_v5.0.2__Lenovo_A6000__Kraft-A6000__Kraft-A6000 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 2028 MiB Done! Elapsed: 00:07:34 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Lenovo Device Manufact.: LENOVO Device Model : Kraft-A6000 Device CPU : MSM8916 Device IntName : Kraft-A6000 Device Version : 5.0.2 CU_SWVer : LENOVO Device Compile : 30-10-2015 03:27:16 AM Device ExtInfo : Lenovo A6000 Load Ok! Operation : Flash [ v1.04 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 08EFE0C2 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E6E07C771 ID_BLOCK_L : C060A78CC654F6BD Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 26 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn ProgStart : start 264192, num 2048 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash [ v1.04 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 08EFE0C2 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E6E07C771 ID_BLOCK_L : C060A78CC654F6BD Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 26 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn ProgStart : start 264192, num 2048 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! thanks advance |
12-02-2016, 17:38 | #2 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | Code: Infinity-Box Qualcomm Module [QLM] v 1.04 Operation : Identify [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BAA85AF ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E6D5D2C42 ID_BLOCK_L : C060A78CC50E1D8E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Lenovo Device Manufact.: LENOVO Device Model : Kraft-A6000 Device CPU : MSM8916 Device IntName : Kraft-A6000 Device Version : 5.0.2 CU_SWVer : LENOVO Device Compile : 30-10-2015 03:27:16 AM Device ExtInfo : Lenovo A6000 Load Ok! Operation : Flash [ v1.04 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BAA85AF ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E6D5D2C42 ID_BLOCK_L : C060A78CC50E1D8E Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 26 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : userdata.img Flashing : gpt_backup0.bin Boot settings configured! Flashing done! Done! Elapsed: 00:06:21 Reconnect Power/Cable! |
12-03-2016, 06:00 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: chandigarh Age: 42
Member: 349524 Status: Offline Sonork: 100.1622727 Thanks Meter: 122 | Quote:
12-03-2016, 06:47 | #4 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Quote:
just press thanks | |
The Following User Says Thank You to iftikhar_246 For This Useful Post: |
08-02-2019, 14:16 | #6 (permalink) |
Junior Member Join Date: Jul 2013 Location: brahampur , odisha Age: 31
Member: 1985472 Status: Offline Thanks Meter: 2 | Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8916.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 16 GB LU Count : 1 [0x01D5C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Failed Operation Finished. QcFire Ver. 4.6 |
08-02-2019, 14:17 | #7 (permalink) | |
Member: 1985472 Status: Offline Thanks Meter: 2 | a6000 flashing Quote:
Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8916.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 16 GB LU Count : 1 [0x01D5C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Failed Operation Finished. QcFire Ver. 4.6 | |
