07-18-2011, 18:46 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 691395 Status: Offline Thanks Meter: 0 | Alcatel MModule here is logs when i have tried to fix security area: COM4 [VCP1] selected module v3.94 Device: Alcatel-355X, 355A, 355DA Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:86F7:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: E:\Program Files\InfinityBox\MModule\backup_security\id.109EB 0B3.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_CE0E9F0E].rpl ==================== New firmware found (v.3.94, database date: 20.06.2011): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 109EB0B3 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 0E9F0ECE code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 46I provider: 355X-2CBYFR1 customization: CI46CRA3 customization: XI46CRA3 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI46CRA3 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->087B1A54 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 file saved: E:\Program Files\InfinityBox\MModule\backup_security\Alcatel-355X,355A,355DA__system_log_109EB0B3_CE0E9F0E_2011 0718-124750.B0X.bin Finished, time used: 2 min 20 sec Remove/Install battery now ! |
07-18-2011, 22:03 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @FETEHG For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock: 1. use "MModule" software v3.22 or newer 2. use "Write" button from software "Service" page and write original imei (from phone back label) 3. make "sp-unlock" |
07-19-2011, 12:59 | #8 (permalink) |
Member: 691395 Status: Offline Thanks Meter: 0 | sorry sir but i am trying without success....please what 's next option....: COM4 [VCP1] selected module v3.96 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 353923041727146 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:86F7:A00C status: 01 boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 9 sec Remove/Install battery now ! |
07-19-2011, 13:01 | #9 (permalink) |
07-19-2011, 13:14 | #10 (permalink) |
Member: 691395 Status: Offline Thanks Meter: 0 | trying to unlock....... COM4 [VCP1] selected module v3.96 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:86F7:A00C status: 01 boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 9 sec Remove/Install battery now ! |
07-19-2011, 13:36 | #11 (permalink) |
Member: 691395 Status: Offline Thanks Meter: 0 | COM4 [VCP1] selected module v3.96 Action: read unlock codes unlock method: read codes Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:86F7:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: MAUI.08A.W08.36.SP1.V34 Version: JRD23_08A_HW detecting structure #2... 1 2 5 7 8 9 11 13 done 80 byte(s) read imei: 35392304172714 connection Ok detecting structure #1... 0 2 3 4 7 8 9 13 14 15 17 20 22 23 24 27 28 29 32warning: wrong packet cs 33 34 35 37error: detection failed (22 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 19 sec Remove/Install battery now ! |
07-20-2011, 21:08 | #13 (permalink) | |
I need flash to Alcatel One Touch Viev db: Be 3, 2 mb,16A | sosin | Alcatel & TCL Old Models | 0 | 02-13-2002 03:47 |
Alcatel BE$ pinouts | GSM Coolhawk | Alcatel & TCL Old Models | 0 | 12-08-2001 15:44 |
NOKIA, ALCATEL EEprom site | Orbital - GSM | GSM Mobile Links | 0 | 04-09-2001 10:31 |
Alcatel One Touch cable needed!!! | tati | Alcatel & TCL Old Models | 0 | 05-17-1999 22:05 |
