08-18-2015, 07:42 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: inside the box Age: 40
Member: 765233 Status: Offline Sonork: 100.1664273 Thanks Meter: 107 | Alcatel one touch 5021E Read phonebook done Operation : Check / Read Info [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A115A59E60E5 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TCT ProdName : Megane ProdModel : ALCATEL ONE TOUCH 5021E Device : Megane_GSM AndroidVer: 4.1.1 MTKxCPU : MT6577 MTKxPRJ : ALPS.JB.MP.V1 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A115A59E60E5 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #2 Read Ok, PhoneBook records extracted : 733 TXT Saved to : C:\InfinityBox\CM2MTK\PhData\MT6575_PhoneBook alcatel.txt Write : 733 CSV Saved to : C:\InfinityBox\CM2MTK\PhData\MT6575_PhoneBook alcatel.csv Write : 733 Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
The Following User Says Thank You to mquimpanes For This Useful Post: |
