Alcatel One Touch Fierce 2 Factory Reset Failed Hi, I have an Alcatel One Touch Fierce 2 from MetroPCS USA (OT-7040N). This model is Qualcomm, and I can't do a factory reset with CM2QLM (Am using new version 1.07). I'm sending you Operation.log and QLM_report.log just as Program says, but this forum refuse to accept files larger than 391.3kb and packed file has 450kb. Where could I send you this file? I hope you can fix this problem, the phone hasn't Recovery Mode and I don't know how to remove the pattern lock. Thanks in advance, merry christmas and have a happy new year, Carlos |
The logs: Operation : Read Flash [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0714B76D ID_BLOCK_I : 008140E1 ID_BLOCK_L : 6C7DA67974D1842067C82294A5FEC3DF ID_BLOCK_L : BAF27D0E4688CE31B52DBE2A815BCE63 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
Hello. Checked on all places, which have access to ( on svc ) and not found anything for that model at all. Unfortunately - have no idea yet. |
