09-20-2009, 06:39 | #1 (permalink) |
Major Poster Join Date: Feb 2004 Location: MAROUA CAMEROUN Age: 59
Member: 52636 Status: Offline Thanks Meter: 5 | Alcatel Ot - 103 pinout py cables infinity pls my ot 103x have connector 1x5 the update is 2x5 Cable name: Alcatel-OT-C701 keyboard down connector 2x5 1 2 3 4 5 6 7 8 9 10 pls Ade anothe pinout tank |
10-08-2009, 10:52 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
10-10-2009, 23:28 | #7 (permalink) |
Member: 52636 Status: Offline Thanks Meter: 5 | alcatel ot-103x connector picture ined hep [IMG]file:///C:/Documents%20and%20Settings/HAXPSP2/Mes%20documents/Ala-103x_pict/Ala-103x_pict01.JPG[/IMG] Last edited by alhassan; 10-10-2009 at 23:33. |
10-19-2009, 00:29 | #9 (permalink) |
Member: 52636 Status: Offline Thanks Meter: 5 | ot-103x [IMG]file:///C:/Documents%20and%20Settings/HAXPSP2/Mes%20documents/Ala-103x_pict/Ala-103x_pict04.JPG[/IMG]file:///C:/Documents%20and%20Settings/HAXPSP2/Mes%20documents/Ala-103x_pict/Ala-103x_pict02.JPG |
12-05-2009, 19:28 | #11 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: China SZ Age: 50
Member: 58924 Status: Offline Sonork: 1583810 Thanks Meter: 57 | OT 103 unlock success Quote:
conector is 1x5 not 2x5 but i unlock one to day by infinity see log COM10 [VCP0] selected module v2.98 Device: Alcatel-103X, 103A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5318:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 175 provider: 103X-2BRGTE1 customization: CM17CA40 customization: XM17CA40 TCL-ID identification done ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM17CA40 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... max address is too big, should be recalculated: 0827D124->0826AF14 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_200912 05-144938.B0X.bin Finished, time used: 115 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
The Following 2 Users Say Thank You to DOCTOR8 For This Useful Post: |
12-08-2009, 22:59 | #12 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: BENIN-Cotonou
Member: 256231 Status: Offline Thanks Meter: 24 | Quote:
12-09-2009, 00:04 | #13 (permalink) |
Member: 52636 Status: Offline Thanks Meter: 5 | Vary very Tank mani tank 1 mount im send iam speak by the picture no one telme the ot -103x have the conector 1x5 plise send me the very pinout for alcatel ot103x [email protected] tank Merci Beaucoup |
12-09-2009, 17:26 | #15 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote: need to show us picture ? then upload it to any image hosting website can be found here and post us a link simple !! Br Faisal_Computer | |
Alcatel ot 103 Unlock probleme | abote didier | Infinity-Box | 4 | 04-26-2010 17:04 |
alcatel ot 103 | alhassan | Infinity-Box | 18 | 03-20-2010 16:44 |
alcatel ot-103 | kobs1 | Infinity-Box | 1 | 10-28-2009 19:14 |
Alcatel Ot - 103 pinout py cables pls help | alhassan | Infinity-Box | 3 | 10-01-2009 13:06 |
alcatel ot-103 ::: USER REQUEST ::: | fokal2008 | PolarBox 3 | 6 | 07-11-2009 21:17 |
