Old 03-20-2010, 12:38   #1 (permalink)
yarra's Avatar
Member: 493205
Sonork: 100.1581647
Thanks Meter: 524
alcatel ot-203a see logo and turn off after sp-unlock
and this is all log
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:54E2:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E221A2201:2BEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is present
rom info detection finished
TCL-ID detection...
TCL-ID detection done
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
code offset: 00000000
ffs offset/size [01]: 003A0000/00058000
TCL-ID identification
version: 37H
provider: 203A-2CTLVE3
customization: CM37NX31
customization: XM37NX31
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 003A0000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, part #2) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100320-122759.B0X.bin
Finished, time used: 1 min 29 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 03-20-2010, 18:03   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,071
For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock:
1. use "MModule" software v3.22 or newer
2. use "Write" button from software "Service" page and write original imei (from phone back label)
3. make "sp-unlock"
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 03-20-2010, 19:38   #3 (permalink)
yarra's Avatar
Member: 493205
Sonork: 100.1581647
Thanks Meter: 524
thank sir work fine but can i change imei .....coz it begaen 011????????????? and here in my contry co'nt calling in this case
Old 03-20-2010, 19:57   #4 (permalink)
Member: 1043909
Thanks Meter: 48,971
Hi,
you can write any imei.
But if this phone imei start from 01.. this means that this phone is for American market and it should has 850/1900 operation band.
I do not think that this phone may works at 800/1900.
You can try to flash phone with 203X firmware but I am not sure that this may helps.
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 03-20-2010, 20:04   #5 (permalink)
yarra's Avatar
Member: 493205
Sonork: 100.1581647
Thanks Meter: 524
thank alot wonderfull team ..................i will try
@ infinity support!!!! .. alcatel ot-203a after imei change . restart in logo residentdenuevo Infinity-Box 3 02-06-2010 21:21
Alcatel OT-203a Ot-103a Reset user data and phone code without box. Celhack Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 10-09-2009 17:32
Nokia 5310 xm show nokia logo and power off after flash???? svchost Universalbox 7 07-24-2009 21:58
v3x turns on and after motorola LOGO,it turns off!!! juvenile Scout 3 07-05-2008 10:25
Page generated in 0.24914 seconds with 8 queries
