07-12-2010, 08:30 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 437 | ALcatel OT-216 Unlock OK But when ON ASSERt FAIL written on SCREEN !! [1] Assert Fails: sL_Trance_Layer....... etc Where is the PROBLEm? I have make SAFE FFS !!1 |
07-12-2010, 08:54 | #2 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 437 | Quote:
Its OK but I make UNLOCK during FLASH phone is still LOCK !! Now am trying to UNLOCK again and will POST results | |
07-12-2010, 09:01 | #3 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 437 | NO after UNLOCK same PROBLEM !!!! Please HELP !!! UNlock Procedure : COM26 [VCP0] selected module v3.49 Device: Alcatel-216X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7A6E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F4017 90C.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_572F5926].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: F401790C rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 26592F57 code offset: 00000000 ffs offset/size [01]: 00700000/000F8000 TCL-ID identification version: 462 provider: 216X-2ERGMG2 customization: CP46CB01 customization: XP46CB01 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00700000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP46CB01 customization name adjusted flash: 98009600000000:2BEA0000000000 flash: 98009600000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98009600000000:2BEA0000000000 flash: 98009600000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 98009600000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98009600000000:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-216X_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_ 36_SP1_V34__system_log_F401790C_572F5926_20100712-115719.B0X.bin Finished, time used: 3 min 27 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to zakiyyboss For This Useful Post: |
07-12-2010, 23:28 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,853 | For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock: 1. use "MModule" software v3.22 or newer 2. use "Write" button from software "Service" page and write original imei (from phone back label) 3. make "sp-unlock" |
07-13-2010, 07:32 | #5 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 437 | NOt WORKING !!!! When on the phone, the phone flashes !!!! And make same problem after RE SP unlock Its URGENT !!! Last edited by zakiyyboss; 07-13-2010 at 07:38. |
07-14-2010, 14:04 | #8 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 437 | Meean it make the same problem that i have POSTED above !! That it ! After make this : 1. use "MModule" software v3.22 or newer 2. use "Write" button from software "Service" page and write original imei (from phone back label) 3. make "sp-unlock" It FREEZE on assert again !!! Need to REMAKE imei again then phone is OK but SIM is LOCK !! |
07-15-2010, 06:37 | #9 (permalink) | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
