12-27-2010, 11:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Location: JATT LABLE Age: 43
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | ALCATEL ot 305 DEAD AFTER UNLOCKING module v3.70 Device: Alcatel-305X, 305A Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__fullflash_part_1_of_1_20101222-031353.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9A9E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F30E7 6F2.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_1382AAEA].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: F30E76F2 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, EAAA8213 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 166 provider: 305X-2DVDKE1 customization: CP16CH10 customization: XP16CH10 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35776903787549 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_F30E76F2_1382AAEA_201 01226-012131.B0X.bin Area: Firmware flash: 01227E22202200:2BEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CP16CH10 customization name adjusted customization: CP16CH10 customization name adjusted customization detected: CP16CH10 customization: CP16CH10 customization: XP16CH10 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_F30E76F2_1382AAEA_201 01226-013446.B0X.bin Finished, time used: 14 min 49 sec Remove/Install battery now ! |
12-28-2010, 06:31 | #4 (permalink) |
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | ot Hi, It came to me in a working condition i unlocked it with infinity it died .............. after that i copied full flash from the a smiler phone and flashed the phone now the phone just shows the alcatel logo and goes off. |
12-28-2010, 22:37 | #5 (permalink) |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | yo bro try this and post log 1- do repair area seecurity 2-do fiormat (complete mode) 3- write imei 4- do unlock |
12-30-2010, 06:27 | #6 (permalink) |
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | @gftelecom Hi, 1-i can only do do repair area seecurity 2- can not do fiormat (complete mode) when i try to format this is what happens COM52 [VCP0] selected module v3.70 Action: reset settings ("format ffs") Model: Alcatel-305X, 305A Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F46:A00C status: 01 Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 23 sec Remove/Install battery now ! i tried do it many times |
The Following User Says Thank You to 4 u man For This Useful Post: |
12-31-2010, 07:06 | #8 (permalink) |
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | @gftelecom Hi, I did complete format then wrote imei and unlocked. but still same COM52 [VCP0] selected module v3.70 Device: Alcatel-305X, 305A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F46:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.DD862 BA2.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_1382AAEA].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: DD862BA2 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, EAAA8213 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 166 provider: 305X-2DVDKE1 customization: CP16CH10 customization: XP16CH10 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: ҹɻ$Ђ⁊Ђく"h%|wM Ljd?5Ҏćt|S.0t^F~ߑW 8$)Eg.Q~7:ZV*%Cî$)BAヤ ou>[`WM9yQo6"aP×|zhk5t~?x ;F?*'G Pe6I?HXh*^ ~S* Dٛ<sjޥٙ⩽ǚӾIsDʈ0~<_as B-ȝ*~M#͡LҶg$ǟ]$N(+ox#s0ɲ!SZZ wjjX?`3^{ Y,ژ5&q¤R|oD|5S+%5wa rning: customization name is unknown Can not calculate required data ! Find original simfree model, read full flash and send to support flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_DD862BA2_1382AAEA_201 01227-174829.B0X.bin Finished, time used: 3 min 43 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-31-2010, 07:08 | #9 (permalink) |
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | can not calculate required data ! Find original simfree model, read full flash and send to support flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... |
12-31-2010, 10:09 | #10 (permalink) |
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | i repeat do repair security area without release the battery do format complet mode and always without release the battery write the imei with the same write behind the phone and after that always without release the battery do unlock,after unlock process release the battery and press the power button and hold more than one minute to power on the phone. a precise this methode is too revive the phone if blinking on alcatel logo.... but if you have the phone in good condition and you want to unlock it first make read firmware save it on the desktop and without release battery write imei at the same on the back of phone and always without release battery do unlock after that press power on button and hold it more than one minute to power the phone and voila your phone is unlocked thk i think it may help you and guy on forum |
01-30-2011, 00:55 | #12 (permalink) |
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | the realy solution is not infinity box but another box infinity support cleary answer me on tis post http://forum.gsmhosting.com/vbb/f296...catel-1194063/ |
help restoring a dead iphone | tmn50 | iPhone 4 / iPhone 4S | 11 | 12-26-2010 15:37 |
How to unlock iPhone 4 4.1 2.10? | lovenelrod | iPhone 4 / iPhone 4S | 1 | 12-26-2010 14:38 |
please help to unlock alcatel ot355 | amounagsm | FuriousGold | 0 | 12-26-2010 13:32 |
