alcatel ot-505 not unlock COM7 selected module v3.26 Périphérique: Alcatel-505X Contrôle des données, attendre ... détection avancé de flash activé Action: rebuild security area ====> Boot ... Appuyez et restez appuiez sur le bouton "Power" dès maintenant! 19200 fixed En route, attendre ... Initialisation [6223:8A05:8A00]... CPU: MT6223 chip: 0011:A349:A00C status: 01 taille de paquet de démarrage: 0400 lachez bouton d'alimentation maintenant! Boot Done ====> Initialiser ... detecting chip #00 in region #00... Flash 98000300000001:2BEA0000000000 Flash Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 le nombre de puce flash / régions détectés: 01/01 Initialiser Done ====> Ensemble bauds ... 115200 Ensemble bauds Done ====> Initialiser Démarrage ... Initialiser Démarrage Done ====> Vérifier l'intégrité du firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.3D77E B81.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_650494BC].rpl rom info detection finished ==================== New firmware detected (v.3.26, database date: unknown): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Lire full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 3D77EB81 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, BC940465 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock statut: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected Customization XP23CQ30 erreur: customization name is unknown Can not calculate required data ! Find original simfree model, read full flash and send to support Flash 98000300000001:2BEA0000000000 Flash 98000300000001:2BEA0000000000 écrire security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern max address is too big, should be recalculated: 08BF8000->086C1620 ..................security area (sec info, part #1) detecting size... erreur: security area (sec info, part #1) size is incorrect: 01C0 instead of 0374 fichier sauvegardé: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-505X__system_log_3D77EB81_650494BC_20100321-144130.B0X.bin Terminé, temps utilisé: 3 min 41 sec Retirez / remettre la batterie maintenant! |
Hello, Code: ==================== |
yeah, he have to, i told him, this is his first post from a long time, so nobody notice it. and this word /nickname, is his password for every thing, so, from this post, he have to change it and change his pass... LoooooooooooooooooooooooooooooooooooooooooooooooL seif, is a good name, so plz, forget tin.nage and move forword.. just be an adul.t Bonne Chance ami B.R .::dkM::. |
