Alcatel OT-600 Unlock Done With Rx,Tx Alcatel (OT-600) Unlock Successful With Rx,Tx. LOG Here: COM7 [VCP0] selected module v2.93 Device: Alcatel-600 Checking data, wait... advanced flash detection enabled Action: write NOR flash "format ffs" active write: Firmware 600X-2EVRGB1-266_XJ26CW10_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V38_2009-06-16_En_Fr_Es_It_De_VM621i_Virgin-UK_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:A203:A00D status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.860F1 0F0.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 860F10F0 rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 address offset: 00020000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2EVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done ffs address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 00000000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_860F10F0_C4B7397C_20091114-085206.B0X.bin Area: Firmware flash: 98000300000001:08EA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..area 0x01 size is zero ................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... customization: CJ26CW10 done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... customization: CJ26CW10 done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_860F10F0_C4B7397C_20091114-091641.B0X.bin Finished, time used: 1565 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-on! Picture Here: http://img404.imageshack.us/img404/3...112009001c.jpg How to make sp-unlock: 1. download "simfree" firmware from support area 2. go to software "Flash" page 3. load "simfree" flash file 4. make "format ffs" box checked 5. flash phone with "simfree" firmware 6. if phone can not Power-On: make "Format ffs" in "complete" mode 7. if phone can not Power-On: make "Repair security area" operation 8. if phone has problems with LCD: select newer firmware for flashing (select by date) Once Again Thanks INFINITY TEAM For Good Support. BR. Waqar ;) |
Good work bro keep it up...........nice info. |
Hello, Here is direct unlock solution for Alcatel models. It's beta solution, need to test it and see what will be the results. Please, try to unlock phone with this new software: http://www.infinity-box.com/download...dule_v2.94.rar It is no need to flash phone, just use "SP-Unlock" button from software "Service" page. Waiting for your results. |
i tested it now..and i unlock the fone.. |
