Old 11-14-2009, 15:43   #1 (permalink)
..::Waqar::..'s Avatar
Member: 904753
Sonork: 100.1583681
Thanks Meter: 2,671
Thumbs up Alcatel OT-600 Unlock Done With Rx,Tx
Alcatel (OT-600) Unlock Successful With Rx,Tx.
LOG Here:
COM7 [VCP0] selected
module v2.93
Device: Alcatel-600
Checking data, wait...
Action: write NOR flash
"format ffs" active
write: Firmware
600X-2EVRGB1-266_XJ26CW10_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V38_2009-06-16_En_Fr_Es_It_De_VM621i_Virgin-UK_simfree.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:A203:A00D
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:08EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.860F1 0F0.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 860F10F0
rom info protocol ver: 05
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V38, 7C39B7C4
address offset: 00020000
ffs offset/size: 00C00000/00400000
TCL-ID identification
version: 266
provider: 600X-2EVRGB1
customization: CJ26CW10
customization: XJ26CW10
TCL-ID identification done
ffs address assigned: 00C00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
original imei: 00000000000000
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_860F10F0_C4B7397C_20091114-085206.B0X.bin
Area: Firmware
Write: Firmware
sec info (fast) detection...
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..area 0x01 size is zero
................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
done
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
..................security area (sec info, part #1) detecting size...
done
done
done
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_860F10F0_C4B7397C_20091114-091641.B0X.bin
Finished, time used: 1565 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-on!
Picture Here:
How to make sp-unlock:
1. download "simfree" firmware from support area
2. go to software "Flash" page
3. load "simfree" flash file
4. make "format ffs" box checked
5. flash phone with "simfree" firmware
6. if phone can not Power-On: make "Format ffs" in "complete" mode
7. if phone can not Power-On: make "Repair security area" operation
8. if phone has problems with LCD: select newer firmware for flashing (select by date)
Once Again Thanks INFINITY TEAM For Good Support.
BR.
Waqar
The Following 8 Users Say Thank You to ..::Waqar::.. For This Useful Post:
Old 11-15-2009, 10:24   #2 (permalink)
Member: 692226
Thanks Meter: 19
Good work bro keep it up...........nice info.
Old 11-16-2009, 21:26   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
Hello,
Here is direct unlock solution for Alcatel models.
It's beta solution, need to test it and see what will be the results.
Please, try to unlock phone with this new software:
http://www.infinity-box.com/download...dule_v2.94.rar
It is no need to flash phone, just use "SP-Unlock" button from software "Service" page.
Waiting for your results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-25-2010, 05:00   #4 (permalink)
Member: 249687
Thanks Meter: 3
i tested it now..and i unlock the fone..
The Following User Says Thank You to byson For This Useful Post:
Old 10-08-2010, 10:32   #5 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
Originally Posted by InfinitySupport View Post
Hello,
link not working pls upload it again
The Following User Says Thank You to dragosgsm For This Useful Post:
Old 10-12-2010, 17:07   #6 (permalink)
Member: 130995
Please, download latest software from Infinity-Box support area.
alcatel Ot 600 Unlock Problem [Answered] sanjoychy Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 4 02-06-2017 12:35
Alcatel OT 600 Unlock Help!!!!!!!!!!!!!!! jitensahani Phone Unlocking Codes & Maps 0 01-18-2010 15:35
Alcatel ot-e256 unlock done with fg naveedbutt FuriousGold 0 12-22-2009 08:30
alcatel OT-600 unlock by imei:( mashraf32 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 10-28-2009 14:41
Page generated in 0.31426 seconds with 8 queries
