Old 02-18-2010, 08:03   #1 (permalink)
jumper-master's Avatar
Member: 641971
Thanks Meter: 34
Do you want to repair/Unlock Q-MOBILE ?
THIS THREAD IS SPEACIALLY FOR PAKISTANI TECHNICIANS.
Do you want to repair/Unlock Q-MOBILE ? yes it is possible with INFINITY BOX,I and my team (jumper-master,asif.arain) created its repair/unlock 1st in the world and worked successfully.
Now i share with you log reports of these type of phones.Try it on 6205-6227 NOR mode,it is MT6223 cpu type and post your result with log report here.
E200
Action: read/check information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6223, E05
Hardware version: TINNO23C_08A_GEMINI_HW
Software version: E200_PAKISTAN_PR1_R3
Software date: 2000.00.00
Barcode: Y2720924002810 10
imei-1: 355***********
imei-2: 355***********
imei-3: 355***********
Finished, time used: 9 sec
Remove/Install battery now !
COM12 [VCP0] selected
module v3.05
Device: Autodetect 6205-6227 NOR
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:96FA:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.05, database date: 11.01.2010):
TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E200_PA KISTAN_PR1_R3_0.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support:
[email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 05
sw version: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E200_PA KISTAN_PR1_R3_0.BIN
project-id: E200_PAKISTAN_PR1_R3.0, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/001F8000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting ffs/eeprom structure pass 1...
detect standard ffs/eeprom location pass #1...
detect extended ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
firmware version: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E200_PA KISTAN_PR1_R3_0.
detecting firmware build...
firmware build: 200905111917
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En Ar
Finished, time used: 1 min 39 sec
User lock code in (standard mode)
module v3.05
Action: "user code"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 00
detecting startup code area #2...
startup code area #2 is absent
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E200_PA KISTAN_PR1_R3_0__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO23C_08A_GEMI NI_PCB01_GPRS_MT6223P_S00.E200_PAKISTAN_PR1_R3_0__ ffs_20100125-143421.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 8 min 18 sec
E400
GENERAL INFORMATION
Connecting, wait...
Hardware version: MT6225, E05
Hardware version: TINNO25_GEMINI_HW
Software version: E400-PK.FM.V7"
Software date: 2006.06.14
Barcode: L2710922009039 10
imei-1: 3578**********
imei-2: 3578**********
imei-3: 3578**********
Finished, time used: 6 sec
DETAILED INFORMATION
COM4 [VCP0] selected
module v3.05
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:7E03:0003
status: FF
Boot Done
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
TCL-ID is absent
TINNO25_GEMINI_PCB01_GPRS_MT6225_S00.E400-PK_FM_V7.BIN
rom info ver: 04
sw version: TINNO25_GEMINI_PCB01_GPRS_MT6225_S00.E400-PK_FM_V7.BIN
project-id: E400-PK.FM.V7, 00000000
ffs offset/size [01]: 00E00000/001F0000
TCL-ID is absent
ffs/eeprom chip: 00
firmware version: TINNO25_GEMINI_PCB01_GPRS_MT6225_S00.E400-PK_FM_V7.BIN
firmware build: 200905262227
done
Finished, time used: 2 min 20 sec
FORMAT IN SAFE MODE
module v3.05
Action: reset settings ("format ffs")
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Connecting at 19200, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: E400-PK.FM.V7
Version: TINNO25_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35783102101528
connection Ok
building list...
done
items to clear: 177
warning: wrong packet cs
items cleared: 177 of 177
building list...
done
items remains: 0
Finished, time used: 32 sec
REPAIR IMEI
IMEI 1
Action: "repair imei"
Connecting, wait...
imei-1: 357************
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 357************
verification Ok
Finished, time used: 5 sec
2nd IMEI
Connecting, wait...
imei-2: 135790246811220
imei write channel: imei #2 for dual sim/mono CPU
new imei-2: 357************
verification Ok
Finished, time used: 3 sec
INFINITY IS THE BEST TOOL FOR CHINESS TYPE PHONES
IF YOU LIKE MY POST JUST HIT THANKS BUTTON
The Following 3 Users Say Thank You to jumper-master For This Useful Post:
Old 02-18-2010, 16:20   #2 (permalink)
Member: 1043909
Thanks Meter: 60,920
Please, read full flash from these models and send full flash backup files (or links) to [email protected]
Old 02-19-2010, 10:26   #3 (permalink)
Member: 641971
Thanks Meter: 34
@yellow boss
Hello
I send infinity team e400 flash file but i forget e200 i try again and send to infinity team.
@infinity team
update infinity shell and add e200
The Following User Says Thank You to jumper-master For This Useful Post:
Old 04-24-2012, 06:05   #4 (permalink)
Member: 1169874
q mobile e500 handfree mod plz help me
Old 04-24-2012, 10:55   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
in most cases this is hardware problem.
start from checking water damage near connector
Do you want to repaire/Unlock Q-MOBILE ? jumper-master Q-Mobile 0 02-17-2010 17:25
Do you want to hear what people are saying around you? spycell Main Sales Section 4 06-07-2002 18:47
Do You Want To Unlock Your Eric Just Today ? Thomass Main Sales Section 0 05-30-2002 07:44
Do you want to do Mobile phone connector Trade in your country. YES>>>IN pcsos Main Sales Section 0 04-02-2002 13:41
Do you want to unlock Savvys??? X-Shadow Various 3 09-28-2000 08:00
Page generated in 0.25382 seconds with 9 queries
