01-15-2016, 18:31 | #1 (permalink) |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | Alcatel OT-991d Invalid imei i want repair imei for this alcatel ot-991d Operation : Repair Security [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 121 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6573 BB_CPU_HW : CA10 BB_CPU_SW : CA01 BB_CPU_SB : CA01 BB_CPU_NM : [MediaTek] MT6573_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1316.0.0.965 DA Stat : v3.2 on BBID : 0x83 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x006D , UNKNOWN [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND Flash not supported yet in that mode! Done! Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Repair Security [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 121 ] Sync... Init Service mode failed, something went wrong Reconnect Power/Cable! in both mode error |
01-15-2016, 18:37 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 1. It ANCIENT device. Very ancient. 2. Alcatel phones have IMEI in OTP, so, correct firmware flashing should help solve problem. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
