06-19-2009, 02:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | alcatel ot-e227 unlocking problem unlocking, COM13 [VCP128] selected module v1.33 Device: Alcatel-E227 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E227_eeprom_calibration-1... file saved: E:\mobile\infinity box\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20090619-063553.80E.bin Read data done Check data ... Check data done Write ... error: unexpected termination/freez: 06000000 error: unexpected termination/freez: 06000000 error: unexpected termination/freez: 06000000 error: unexpected termination/freez: 06000000 error: unknown structure, read flash and send to support ! Write fail error: operation failed Finished, time used: 122 sec Remove/Install battery now ! flash reading, COM13 [VCP128] selected module v1.33 Device: Alcatel-E227 "advanced chip detection" active Action: read full flash Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E227_flash_part_1_of_1... warning: wrong data size at 0x06014400, retry... warning: wrong data size at 0x06014400, retry... warning: wrong data size at 0x06014400, retry... warning: wrong data size at 0x06014400, retry... warning: wrong data size at 0x06014400, retry... warning: wrong data size at 0x06014400, retry... warning: wrong data size at 0x06014400, retry... warning: wrong data size at 0x06014400, retry... warning: wrong data size at 0x06014400, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? aborted by user error: operation failed Finished, time used: 134 sec Remove/Install battery now ! any idea?? br. |
06-19-2009, 11:19 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
07-14-2009, 07:09 | #3 (permalink) |
Registered User Join Date: May 2007 Location: india
Member: 511520 Status: Offline Sonork: 100.1573642 Thanks Meter: 127 | COM1 [Serial0] selected module v1.34 Device: Alcatel-E227 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E227_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20090714-103041.80E.bin Read data done Check data ... Check data done Write ... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 84 sec Remove/Install battery now ! press power button & don't release untill operation is finished unlock done |
The Following User Says Thank You to dhawan_boss007 For This Useful Post: |
Alcatel ot-c550 unlock problem | rubeltelecom | FuriousGold | 18 | 01-20-2013 12:03 |
Alcatel ot 103 Unlock probleme | abote didier | Infinity-Box | 4 | 04-26-2010 17:04 |
Alcatel OT-E227 unlock??????? | dragosgsm | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 3 | 02-18-2009 23:15 |
alcatel ot-s210x unlock problem plz help | asif_ae | Multi-Box | 7 | 12-14-2008 11:25 |
alcatel ot-c560x unlock problem | Shakeel Communication | FuriousGold | 8 | 09-16-2008 07:54 |
