11-27-2008, 08:29 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: PK, Remote Unlocking Services,
Member: 558087 Status: Offline Sonork: 100.1579413 Thanks Meter: 332 | Alcatel OT-S211 And Sonyericsson J132 Unlocked Succesfull, Alcatel OT-S211 Unlocked Succesfull, Here is log, COM6 [VCP1] selected Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-S211_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20081127-102301.80E.bin Read data done Check data... Check data done Writing... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 97 sec Remove/Install battery now ! ------------------------------------------------------ Sonyericsson J132 Unlock Succesfull,, Here is log, COM20 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081127-121547.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 68 sec Remove/Install battery now ! |
The Following 7 Users Say Thank You to gujjar_brothers For This Useful Post: |
11-27-2008, 09:27 | #2 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. wbr |
11-27-2008, 11:03 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | sony ericsson j132 unlock done by yasermalik on infinity box using unicable connector_usb_mini-5 _____ /12345\ _______ 1: Gnd 3: Box Rx/Phone Tx (RJ45 pin-3) 4: Box Tx/Phone Rx (RJ45 pin-2) use same pin and press sp-unlock when it says finalizing... then press fone power button again dnt 4get thankx COM4 [VCP2] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081126-231009.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 78 sec Remove/Install battery now ! thanx infinity team good work keep it up br yasermalik doc-unlock dadyal 03436360983 |
The Following 3 Users Say Thank You to yasermalik For This Useful Post: |
11-27-2008, 11:46 | #6 (permalink) | |
Member: 558087 Status: Offline Sonork: 100.1579413 Thanks Meter: 332 | Quote:
11-28-2008, 17:07 | #7 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | i didn't made any thread it was just test report is da gsm fourm urs r only u can make thread? nd no 1 can post his test report? boss dnt worry you 'll get ur credite nd anyway alcatel nd sony ericsson r 2 spreat brands thnx nd keep it up thnx goes to infinity team they work hard we just use n abouse thnx infinity team br yasermalik |
The Following 2 Users Say Thank You to yasermalik For This Useful Post: |
10-10-2010, 18:37 | #9 (permalink) | |
Freak Poster Join Date: Aug 2008 Location: Zanzibar
Member: 845667 Status: Offline Thanks Meter: 40 | Quote:
COM44 [VCP0] selected module v1.38 Device: Alcatel-S211 "advanced chip detection" active Action: user code Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S211_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20101010-202653.80E.bin reading Alcatel-S211_ffs... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_ffs_20101010-202843.80E.bin Read data done Check data ... pass-1... pass-2... Check data done Write ... flash: 012A7E2A242A00:54000000000000 Write: ffs Write done Finished, time used: 3 min 0 sec Remove/Install battery now ! | |
The Following User Says Thank You to maguvu For This Useful Post: |
Alcatel OT 206 and samsung 2120 unlock[ USER REQUEST ] | djouaka | PolarBox 3 | 7 | 11-07-2017 16:47 |
cannot unlock Alcatel OT-S211 ::: ANSWERED ::: | hugmax | PolarBox 3 | 1 | 09-14-2009 14:24 |
alcatel ot-s211 orange unlock | nightmit | Infinity-Box | 1 | 01-16-2009 20:35 |
Alcatel OT-S211 successfully unlocked with micro-box | UnlockingLab | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 01-04-2009 22:29 |
alcatel ot s211 unlock help | webzone136 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 11-21-2008 14:42 |
