04-18-2009, 19:25 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
05-11-2009, 14:21 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 95476 Status: Offline Thanks Meter: 185 | Phone info: ~~~~~~~~~~~ Phone Model: OTS319/S319A Revision: Alcatel 010 06, 2008/10/29 13:25 IMEI: 352394022117684 Manufacturer: Alcatel Connected to server Unlock codes: ------------- NCK: 1278874364 SPCK: 2114620262 Disconnected from server just invers gnd tx rx to left |
05-17-2009, 12:14 | #7 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | Quote:
04-16-2011, 12:48 | #8 (permalink) |
Freak Poster Join Date: May 2007 Location: islamabad
Member: 509880 Status: Offline Thanks Meter: 16 | module v3.79 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:23A9:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN project-id: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 16U provider: S319X-2FRGGB1 customization: CH16CB31 customization: XH16CB31 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XH16CB31 customization name adjusted flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35239402380018 flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20110416-164342.B0X.bin Finished, time used: 4 min 42 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to batishd2004 For This Useful Post: |
01-14-2012, 09:59 | #10 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Sri lanka Age: 43
Member: 454011 Status: Offline Sonork: 1656095 Thanks Meter: 147 | Alcatel OT s319 unlock with infinity COM25 [VCP0] selected module v3.75 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:0D05:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN project-id: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 16U provider: S319X-2ARGGB1 customization: CH16CB31 customization: XH16CB31 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XH16CB31 customization name adjusted flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35239402029016 flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Infinity\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20120114-142730.B0X.bin Finished, time used: 4 min 9 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-14-2012, 11:21 | #11 (permalink) |
Member: 454011 Status: Offline Sonork: 1656095 Thanks Meter: 147 | Try to soldering cable surajnad;8070633]COM25 [VCP0] selected module v3.75 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:0D05:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN project-id: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 16U provider: S319X-2ARGGB1 customization: CH16CB31 customization: XH16CB31 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XH16CB31 customization name adjusted flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35239402029016 flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Infinity\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20120114-142730.B0X.bin Finished, time used: 4 min 9 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ![/QUOTE] |
alcatel ot-s319 correct pinout and tested | MGT SOFTWARE | Infinity-Box | 4 | 03-28-2010 17:14 |
alcatel ot-s319 pinout need | mobile_sos | Infinity-Box | 14 | 02-05-2010 16:05 |
seccsesfuly unlocked Alcatel-OT-S319 | zkb | Infinity-Box | 18 | 08-24-2009 05:08 |
Alcatel OT-S319 unlocking? | mobile-phone-service | Easy-Unlocker | 14 | 10-25-2008 18:12 |
