09-02-2009, 13:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | <<<< Alcatel OT-s319 Unlock Help >>>> |
09-02-2009, 14:19 | #4 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | download simfree flash file from support area and flash with that file 1st of all operation read full flash and read eeprom for your safety good luck |
The Following User Says Thank You to shahzaadbutt For This Useful Post: |
09-03-2009, 08:34 | #6 (permalink) |
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | <<< Alcatel S319 unlock successfull >>> alcatel s319 succssfull unlock with infinity box , download this simfree file from support area & flash with this file, done. S319X-2FVDIT1-16Q_XH16DS32_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_simfree.B0M COM4 [VCP0] selected module v2.83 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware S319X-2FVDIT1-16Q_XH16DS32_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:25C1:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090903-121013.B0X.bin Area: Firmware flash: 98000300000001:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16DS32 done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090903-121951.B0X.bin Finished, time used: 614 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to khadim100 For This Useful Post: |
09-12-2009, 09:33 | #7 (permalink) |
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | ::::::::::: another Alcatel S319 unlock successfull ::::::::::::: COM4 [VCP0] selected module v2.83 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware S319X-2GALGB1_XH16AE31_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2009-02-04_En_Fr_De_Nl_Tr_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:0D36:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) check... security area (code #1) fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090912-130054.B0X.bin Area: Firmware flash: 98000300000001:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16AE31 done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090912-132259.B0X.bin Finished, time used: 1355 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to khadim100 For This Useful Post: |
11-18-2009, 19:25 | #8 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Jamaica Age: 41
Member: 162707 Status: Offline Thanks Meter: 66 | HI, My auto pin finder is not finding the phone. When i selected the pre saved s319 the infinity software wont detect my phone can you help me? I use the L10C cable is that correct? I am awaiting your speedy response. Venom |
11-18-2009, 19:59 | #9 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
do you follow user manual and power phone not from battery, but using pinfinder power lines? Can you power On phone using this power? | |
11-19-2009, 18:49 | #11 (permalink) | |
If you need to unlock this phone urgently you can solder wires to test points under phone battery. If you want to connect it via PinFinder, try to double check that cable connector (2x5 pin) fit into phone connector well. Ordinary it should be no problems with built-in pinouts that was selected from list. | |
01-09-2010, 18:13 | #12 (permalink) |
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | another Alcatel S319 unlock successfully COM4 [VCP0] selected module v3.00 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware S319X-2GALGB1_XH16AE31_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2009-02-04_En_Fr_De_Nl_Tr_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:3B25:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN project-id: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 16T provider: S319X-2FRGGB1 customization: CH16CB31 customization: XH16CB31 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent rom info relocation detected startup code area #1 check... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20100109-183811.B0X.bin Area: Firmware flash: 98000300000001:2AEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CH16AE31 customization: CH16AE31 flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20100109-184828.B0X.bin Finished, time used: 12 min 12 sec Remove/Install battery now ! |
Alcatel ot-s319 unlocked | cellcarekphb | Easy-Unlocker | 5 | 06-01-2009 15:15 |
ALCATEL OT-s319 unlock problem. | aleem26 | Easy-Unlocker | 1 | 04-09-2009 18:23 |
Alcatel ot s319 unlock ? | webzone136 | Infinity-Box | 1 | 02-28-2009 18:59 |
Alcatel OT-S319 unlocking? | abu3131 | Easy-Unlocker | 3 | 02-15-2009 23:01 |
Alcatel OT-S319 unlocking? | mobile-phone-service | Easy-Unlocker | 14 | 10-25-2008 18:12 |
