Old 11-17-2009, 10:05   #1 (permalink)
gesundheit's Avatar
Member: 17851
Thanks Meter: 153
Question Alcatel OT-S319A Direct Unlock Success But No Network
COM189 [VCP6] selected
module  v2.94
Device: Alcatel-S319X, S319A
Checking data, wait...
Action: rebuild security area
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:1CED:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is present
rom info detection finished
TCL-ID detection...
TCL-ID detection done
rom info protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
address offset: 00000000
ffs offset/size: 00C00000/00400000
TCL-ID identification
version: 16L
provider: S319A-2ACIJM1
customization: CH16PC30
customization: XH16PC30
TCL-ID identification done
ffs address assigned: 00C00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, part #2) calculation...
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20__system_log__00000000_20091117-164150.B0X.bin
Finished, time used: 171 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Sadly, No Network after Unlock here in my country.
..will flashing this phone able to convert it to work in 900-1800Mhz?
Old 11-17-2009, 12:03   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,397
Hello,
I am not sure in results, but you can try to flash phone with S319X firmware.
Please, post here your results.
Old 11-18-2009, 09:34   #3 (permalink)
gesundheit's Avatar
Member: 17851
Thanks Meter: 153
1. Tried flashing EEPROM from support (S319X_repair_eeprom_ffs_universal_4m.B0E.bin)
2. Tried Writing NEW IMEI
3. Tried Flashing Firmware (S319X-2FVDIT1-16Q_XH16DS32_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_simfree.B0M.bin)
RESULT:
Phone now can call EMERGENCY, able to search Networks, but phone displays EMERGENCY. After doing manual network search> Not allowed was the phone's response.
Re-wrote backup Original EEP, phone returns back to No SERVICE.
Any thoughts on this? Thanks.
Old 11-18-2009, 10:06   #4 (permalink)
gesundheit's Avatar
Member: 17851
Thanks Meter: 153
UPDATE: Phone now has network after writing only EEP (S319A_repair_eeprom_ffs_universal_4m.B0E.bin) but signal unstable. Sometimes it is in EMERGENCY mode. Tested phone in sending/receiving SMS. In/Out Calling OK. Thanks. Still hoping to have a more stable fix for this.
Old 11-18-2009, 11:36   #5 (permalink)
Cheater -Don't Deal with him-
Member: 265129
Thanks Meter: 281
Flash With this File S319X-2FVDIT1_XH16DS32_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_simfree.B0M
100% Working I have tested it.
brb.
.::[email protected]/\/::.
Old 11-20-2009, 07:00   #6 (permalink)
gesundheit's Avatar
Member: 17851
Thanks Meter: 153
@faizanbhatti94
is your network stable?
BTW our country uses 900/1800 on 2gsm
Old 03-03-2010, 18:12   #7 (permalink)
Member: 42981
Sonork: 1583521
Thanks Meter: 9
thanks it worked thanks alot for my s319x
J220A unlock successfully but no network. Ducdung76 Sony Ericsson Hardware Repair 1 02-15-2010 13:28
Alcatel ot s 520x unlock succefully but gsm5378 Infinity-Box 4 11-16-2009 22:26
motorola w220 unlocked by infinity successfully but no network mahesh gandhi Infinity-Box 1 10-05-2008 22:40
IMEI patch success but no network found.. Jabir27 Nokia Digital Core Technology 4 ( DCT-4 ) 9 06-07-2008 20:42
Help i607 from at&t "Phone PIN" Direct Unlock successful but still Lock vanhh UST Pro II 3 12-17-2007 21:41
Page generated in 0.75739 seconds with 8 queries
