Old 12-22-2008, 13:10   #1 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 446
Alcatel OT S320 can't boot
Hi,ALL
I have OT S320 to unlock but can't boot.
batt full charge
cable ok
I have tryed use all variant for connecting problem as Motorola in doc manual
No resultat.
Please help.
my box works very well.
help please.
Old 12-22-2008, 14:07   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,185
Unlock By Tp Mathod .......
Old 12-22-2008, 16:11   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,388
Originally Posted by said4 View Post
Hi,ALL
batt full charge
cable ok
No resultat.
Please help.
help please.
Hello,
You need to double check cable.
If you can not connect via phone connector it may be that you need to solder wires to test-points under battery.
Old 12-22-2008, 17:02   #4 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,062
if u have KG195 cable just open it and swap RX TX
MapleGsm(Umer)
Old 12-22-2008, 18:25   #5 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 446
Thanks for reply
I use TP method and I know how to solder it but for me not boot.
It's as C701 TP.
Old 12-22-2008, 19:09   #6 (permalink)
Member: 130995
Hello,
Please, double check your cable, I don't see any other reason why phone can not boot.
Old 12-22-2008, 19:17   #7 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 446
At last Phone unlocked
I use FG Box to connect phone and voila working.
what you advice us about?
Direct to InfinityBox not working
with Pinfinder not working too
COM4 [VCP1] selected
module v2.52
Device: Alcatel-OT-S320X
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
error: boot initialization step #2 failed:
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:3192:A00C
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20081222-204948.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CH16BM13
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
use default security area (code #3, part #1) pattern
..................done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20081222-205849.B0X.bin
Finished, time used: 558 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 12-22-2008, 20:31   #8 (permalink)
Member: 130995
Hello,
Please, check box with other phones in future, probably there is some problems with RJ45 socket or something like this.
Alcatel OT-S320 can infinity support it nzeiga Infinity-Box 32 07-25-2010 19:40
alcatel ot-s320 and ot-600 product password MGT SOFTWARE Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 6 01-10-2010 08:34
Alcatel OT S320 ? Unlocker AL Alcatel TCL Phones and New Models 2 09-26-2008 11:28
Can unlock Alcatel OT S320 Easy unlocker? Matrix rev Easy-Unlocker 0 09-25-2008 16:38
Page generated in 0.30360 seconds with 8 queries
