alcatel ot s320 whithc cable to use hello i heve one alcatel ot-s320 movistar branded and i want to unlock. allways recive this error: COM8 [VCP0] selected module v2.54 Device: Alcatel-OT-S320X Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! and after i press power button nothing happen. |
Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) http://www.infinity-box.com/download...shell_v126.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
i buided a jtag cable for unlock the phone, but i recive a error. this is the log COM8 [VCP0] selected module v2.54 Device: Alcatel-OT-S320X Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:11CC:A00C high speed boot Off boot packet size: 000A Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 error: wrong answer: C3 error: can't work at this speed, use lower speed Set baud FailFinished, time used: 28 sec Remove/Install battery now ! |
Hello, Code: error: can't work at this speed, use lower speed |
COM8 [VCP0] selected module v2.54 Device: Alcatel-OT-S320X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:11CC:A00C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20081224-033015.B0X.bin Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: 98004900000002:2AEA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16AB12 done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20081224-033412.B0X.bin Finished, time used: 262 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
1 Attachment(s) wrong pinouts plz correct this |
@ahmertelecom What is wrong with that pinout ? |
you have to change the GND and RX |
1 Attachment(s) see this picture ! br. The_dj |
