Old 12-22-2008, 20:42   #1 (permalink)
Member: 178450
Thanks Meter: 53
alcatel ot s320 whithc cable to use
hello
i heve one alcatel ot-s320 movistar branded and i want to unlock. allways recive this error:
COM8 [VCP0] selected
module v2.54
Device: Alcatel-OT-S320X
Checking data, wait...
Action: read NOR flash
Boot ...
and after i press power button nothing happen.
Old 12-22-2008, 21:16   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 12-23-2008, 13:53   #3 (permalink)
Member: 178450
Thanks Meter: 53
i buided a jtag cable for unlock the phone, but i recive a error. this is the log
module v2.54
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:11CC:A00C
high speed boot Off
boot packet size: 000A
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
921600
error: wrong answer: C3
error: can't work at this speed, use lower speed
Set baud Fail
Finished, time used: 28 sec
Remove/Install battery now !
Old 12-23-2008, 17:20   #4 (permalink)
Member: 130995
Hello,
Please, try to use 46800 baud.
Old 12-24-2008, 00:26   #5 (permalink)
Member: 178450
Thanks Meter: 53
Originally Posted by InfinitySupport View Post
Hello,
after some connection problems , i build a jtag cable and phone is now unlocked. here is tle log:
module v2.54
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
boot packet size: 0400
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
sim-lock status: disabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20081224-033015.B0X.bin
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
security area (code #3, part #2) calculation...
customization: CH16AB12
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
use default security area (code #3, part #1) pattern
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20081224-033412.B0X.bin
Finished, time used: 262 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to the sorrow For This Useful Post:
Old 12-24-2008, 08:26   #6 (permalink)
Member: 130995
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 02-21-2009, 13:53   #7 (permalink)
ahmertelecom's Avatar
Member: 210880
Sonork: 100.1577765
Thanks Meter: 148
wrong pinouts plz correct this
Old 02-21-2009, 17:44   #8 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
@ahmertelecom
What is wrong with that pinout ?
Old 04-17-2009, 20:39   #9 (permalink)
Member: 214397
Thanks Meter: 4
you have to change the GND and RX
Old 04-17-2009, 22:10   #10 (permalink)
The_Dj's Avatar
Member: 178790
Sonork: 100.1593063
Thanks Meter: 1,234
see this picture !
br.
The_dj
Alcatel OT-S320 can infinity support it nzeiga Infinity-Box 32 07-25-2010 19:40
alcatel ot-s320 and ot-600 product password MGT SOFTWARE Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 6 01-10-2010 08:34
Alcatel OT S320 ? Unlocker AL Alcatel TCL Phones and New Models 2 09-26-2008 11:28
Can unlock Alcatel OT S320 Easy unlocker? Matrix rev Easy-Unlocker 0 09-25-2008 16:38
Page generated in 0.38584 seconds with 9 queries
