06-08-2009, 16:00 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | flash with sim free serbian file if after flash set becomes white display then flash with t mobile firmware your phone will be with good display but locked so you have to wait for future update.... |
06-09-2009, 06:46 | #3 (permalink) |
Freak Poster Join Date: May 2008
Member: 770127 Status: Offline Thanks Meter: 37 | where are infinity supporters.plz help me.i have Alcatel ot-s621( lobster virgin mobile) i will try all sim free files .but after flash phone dead or blue screen.or write same backup file phone will working fine.but locked . i need perfect unlocking solution. thanx in advance . |
06-09-2009, 08:49 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
1. Flash with file S621X-2AALAP1_XD54BM02_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-07-22_En_Fr_Serbian_simfree.B0M.bin after flash mobile will not power on. 2. than Format FFS (select complete ) still mobile will not power on 3. than click "repair security zone". now mobile will power on and unlocked | |
The Following User Says Thank You to hasnain For This Useful Post: |
06-09-2009, 09:02 | #5 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | FLASH WITH THIS FILE UR SET IS ALIVE WITH DISPLAY BUT LOCKED use this file S621X-2ATBMK1_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile.B0M |
06-09-2009, 09:44 | #6 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2007 Location: Inside of my computer
Member: 490708 Status: Offline Sonork: 100.1587135 Thanks Meter: 569 | Not possible to unlock yet .if u,ve poler box then yes u ca unlock if not then wait for great infinity team update. br |
08-07-2009, 08:52 | #7 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Pakistan
Member: 559810 Status: Offline Sonork: Not use Thanks Meter: 176 | i change the imei and i flash the set ewith given file and sim free dile but set dosnt working still lock infinty dosnt working good lucky121 |
08-13-2009, 07:02 | #10 (permalink) |
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | Yes brother you can unlock with flash file it 100% working infinity box.....................Try to flash last fimware if you use low firmware your fone goes blue display ... so use high fimware......... Br. amar181 |
09-18-2009, 09:11 | #12 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Kosova
Member: 87568 Status: Offline Thanks Meter: 101 | Succesfull flash and unlock without any modification OT-S621: COM3 [VCP2] selected module v2.83 Device: Alcatel-S621X, S621A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware S621X-2AALBG1-556_XD55BU40_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2009-01-07_En_Serbian_Tr_Bg_Al_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2603:A004 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.6876C D03.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_26DFC24B].rpl identification#1 detection finished device-id: 6876CD03 identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, B43D20D9 ffs offset/size: 01020000/00FE0000 ffs address assigned: 01020000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002025416 Backup required data Done Patch required data ... Patch required data Done Special operation ... firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done Write ... security area (code #1) check... security area (code #1) calculation... security area (code #1) fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_6876CD03_26DFC24B_20 090918-005020.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD55BU40 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 01227E22422200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_6876CD03_26DFC24B_20 090918-010336.B0X.bin Finished, time used: 834 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 3 Users Say Thank You to GsmGalant For This Useful Post: |
10-08-2009, 15:31 | #15 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | I tried with latest MM module V2.91 but still having same problem ,,, phone is from virgin Mobile and everytime i flash with sim free flash it turns on with blue screen ,,, I have to flash it back with Virgin flash file ANY CLUE WHY IT IS GOING TO BLUE SCREEN AND SOLUTION PLEASE <<???? THANKS MIKE |
Alcatel OT-S621 unlock? | Bmt_HR | Infinity-Box | 28 | 08-26-2014 08:48 |
Alcatel ot 103 Unlock probleme | abote didier | Infinity-Box | 4 | 04-26-2010 17:04 |
Alcatel OT-S621 unlock | Bmt_HR | Easy-Unlocker | 4 | 04-13-2009 05:05 |
Alcatel/Lobster OT-S621 Unlock | MFC | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 3 | 02-15-2009 12:04 |
How to Unlock the Alcatel OT-S621 | N/East Unlocker | Infinity-Box | 12 | 02-13-2009 12:15 |
