Old 09-04-2010, 14:12   #1 (permalink)
Member: 416112
Thanks Meter: 30
Alcatel ot208 unlock error
Mr YellowBoss,
Ot208x blue screen after unlock. Here is log and i have sent original flash to [email protected]
==== [9/4/2010 12:50:01 PM] ====
COM3 [VCP0] selected
module v3.56
Device: Alcatel-208A
Checking data, wait...
Action: "repair imei"
new imei: 359909036851532
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:53C2:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 8C22F60000000D:2BEA0000000000
flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is present
rom info detection finished
TCL-ID detection...
TCL-ID detection done
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
code offset: 00000000
ffs offset/size [01]: 003A0000/00058000
TCL-ID identification
version: 76G
provider: 208X-2BRGTE8
customization: CM76CE80
customization: XM76CE80
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 003A0000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: FFFFFFFFFFFFFF
Backup required data Done
====> Patch required data ...
pass #1
firmware remap[01]: 08000000
pass #2
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write: imei
sec info (fast) detection...
security area (sec info, cust) calculation...
identification header detected
error: relocation table offset is unknown
error: jump table is not found or incorrect, can't detect customization version
error: can't calculate security area (sec info, cust), existing data will be used
Check support area for updates !
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-208A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__system_log__00000000_20100904-125311.B0X.bin
Finished, time used: 2 min 50 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
==== [9/4/2010 12:53:15 PM] ====
module v3.56
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
TCL-ID detection...
rom info ver: 05
version: 76G
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
customization name adjusted
Write: security area (sec info, cust)
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-208A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__system_log__00000000_20100904-125525.B0X.bin
Finished, time used: 2 min 5 sec
Old 09-04-2010, 14:15   #2 (permalink)
Member: 1043909
Thanks Meter: 52,054
Hi,
try to repair imei with original value from phone back label.
What is the results ?
Old 09-04-2010, 14:42   #3 (permalink)
Member: 416112
Thanks Meter: 30
YellwBoss no result but after i write this file phone comes on but no network
208A-2BAVAR1-76D_XM76NS80_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_F1_2010-05-14_En_Fr_Es_It_Pt.B0M
Old 09-04-2010, 19:20   #4 (permalink)
Super Moderator
Braycel's Avatar
Member: 813309
Sonork: (Off Line)
Thanks Meter: 1,823
Bro Please Read Used Firm For 208x Not For 208a You 208 is 208x
The Following User Says Thank You to Braycel For This Useful Post:
Old 09-04-2010, 23:11   #5 (permalink)
Nadjombe's Avatar
Member: 185608
Thanks Meter: 581
And then unlock done or not?Need repport!!!!!!!!!!!
Old 09-11-2010, 06:21   #6 (permalink)
Member: 534374
Thanks Meter: 8
Same problem my friend....blue screen after unlock, but only firmware "76G".....then repair imei, flash....and nothing, the phone is locked.
But i have other 208A firmware "765".....working ok after "SP-unlock"
Support...any solution??
Old 09-11-2010, 11:07   #7 (permalink)
Member: 1043909
We hope to fix it in nearest time.
Old 09-11-2010, 17:00   #8 (permalink)
Nadjombe's Avatar
Member: 185608
Thanks Meter: 581
Lightbulb Blue screen solution!
Choose OT-203 and perform all!Phone will be unlocked and working.
If new OT-208 need testpoint follow Nadjombe
The Following User Says Thank You to Nadjombe For This Useful Post:
Old 09-12-2010, 18:38   #9 (permalink)
Grand S's Avatar
Member: 954179
Thanks Meter: 82
Thumbs up OT-208 bleu screen!
Working bro!
thank you for ever!!!!!!!!!!
Old 09-13-2010, 12:44   #10 (permalink)
Member: 399519
thank you nadjombe:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 15:21
Page generated in 0.37638 seconds with 8 queries
