Old 01-24-2011, 19:15   #1 (permalink)
nyakam's Avatar
Member: 260658
Thanks Meter: 184
Alcatel ot255 dead
@, i try to unlock alcatel ot255 but phone dead after unlock procedure, any help to revive the phone please?
repair imei procedure:
Loading data, wait...
[Infinity Box] MModule v3.72
smart-card: connected
S/N: 68AF:0116
Wait...
Device: Alcatel-255X, 255A
Done
==== [24/01/2011 13:55:07] ====
COM4 [VCP0] selected
==== [24/01/2011 13:57:21] ====
module v3.72
Checking data, wait...
Action: "repair imei"
new imei: 351762042997395
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:7C7B:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C4591 85C.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_D4C677EA].rpl
New firmware found (v.3.72, database date: 23.12.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: C459185C
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN
project-id: MAUI.08A.W08.36.SP1.V34, EA77C6D4
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 96I
provider: 255X-2ARGTE1
customization: CP96CMA1
customization: XP96CMA1
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35176204299739
Backup required data Done
====> Patch required data ...
pass #1
firmware remap[01]: 08000000
pass #2
pass #3
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write: imei
Write: imei
sec info (fast) detection...
security area (sec info, cust) calculation...
identification header detected
relocation table detected
name table[00] #7000000 detected
customization name adjusted
customization detected: CP96CMA1
error: can't calculate security area (sec info, cust), existing data will be used
Check support area for updates !
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
version is not found in database: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->087C1178
..................security area (sec info, hash) detecting size...
error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_D4C677EA_2011 0124-140239.B0X.bin
Finished, time used: 4 min 57 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
UNLOCK PROCEDURE:
==== [24/01/2011 14:02:46] ====
module v3.72
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: C459185C
rom info ver: 05
version: 96I
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
Write: security area (sec info, cust)
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A__system_log_C459185C_D4C677EA_20110124-140517.B0X.bin
Finished, time used: 2 min 28 sec
==== C:\Program Files\InfinityBox\MModule\MModule.exe [24/01/2011 14:42:47] ====
web site: Infinity-Box - About
S/N: 68AF:0116
Wait...
Done
Loading file v.05...
255A-2CRGDO3-968_XP96NT31_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_ 08A_W08_36_SP1_V34_2010-07-20_En_Fr_Es_It_Pt.B0M.bin loaded
usb bootloader (file) is absent
rom info ver: 05
project-id: MAUI.08A.W08.36.SP1.V34, C2CD0B3F
TCL-ID is present
file w/protection: startup code area #1
firmware date/time: 2010-07-20 21-23
hw1: JRD23_08A_HW
hw2: 08A_JRD23_08A
==== [24/01/2011 14:44:06] ====
module v3.72
Action: write flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C4591 85C.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_3F0BCDC2].rpl
TCL-ID detection...
device-id: C459185C
rom info ver: 05
version: 96I
TCL-ID is present
sim-lock status: disabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
====> Write ...
startup code area #1 calculation...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_3F0BCDC2_2011 0124-144517.B0X.bin
Area: Firmware
Write: Firmware
customization: CP96NT31
customization detected: CP96NT31
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Write Done
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_3F0BCDC2_2011 0124-145133.B0X.bin
Finished, time used: 7 min 7 sec
I DOWNLOAD NEW VERSION 3.73 AN REPEAT UNLOCK PROCEDURE, BUT PHONE STILL NO POWER UP
NEED HELP PLEASE
Old 01-26-2011, 00:07   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
1. make full flash backup
2. send full flash backup file (or link) to [email protected]
3. send this file to [email protected] (exactly the same file as shown below):
4. flash phone with any firmware from support area
what is the results ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 01-26-2011, 19:35   #3 (permalink)
nyakam's Avatar
Member: 260658
Thanks Meter: 184
Phone still dead
[Infinity Box] MModule v3.73
S/N: 68AF:0116
Wait...
Done
255X-901_XP92BJ30_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_ 08A_W08_36_SP1_V34_2010-04-15_En_Cn_Cn.B0M.bin loaded
rom info ver: 05
project-id: MAUI.08A.W08.36.SP1.V34, E9F13744
TCL-ID is present
firmware date/time: 2010-04-15 10-21
hw1: JRD23_08A_HW
hw2: 08A_JRD23_08A
==== [24/01/2011 18:21:57] ====
COM83 [VCP0] selected
COM83 not available
Abort operation ?
error: can't open COM83
module v3.73
COM9 ready
COM10 ready
COM1 ready
COM83 not available
Abort operation ?
==== [24/01/2011 18:22:38] ====
module v3.73
Action: write flash
write: Firmware
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: C459185C
rom info ver: 05
version: 901
customization: CP92BJ30
customization: XP92BJ30
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
====> Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_3F0BCDC2_2011 0124-182355.B0X.bin
Area: Firmware
Write: Firmware
customization detected: CP92BJ30
done
Write Done
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_3F0BCDC2_2011 0124-183615.B0X.bin
Finished, time used: 13 min 17 sec
Old 01-27-2011, 11:42   #4 (permalink)
nyakam's Avatar
Member: 260658
Thanks Meter: 184
@ Sir fullflash read on good set an dead set log file send to support
The Following User Says Thank You to nyakam For This Useful Post:
Old 01-28-2011, 04:22   #5 (permalink)
Member: 130995
Hello,
please, try to make "Repair security area" operation.
What is the results ?
Old 01-28-2011, 12:01   #6 (permalink)
nyakam's Avatar
Member: 260658
Thanks Meter: 184
@sir, here is Repair security log:
module v3.73
Action: repair security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C4591 85C.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_4437F1E9].rpl
TCL-ID detection...
device-id: C459185C
rom info ver: 05
version: 901
TCL-ID is present
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_4437F1E9_2011 0124-154623.B0X.bin
Finished, time used: 2 min 58 sec
Old 01-29-2011, 09:14   #7 (permalink)
Member: 361348
Thanks Meter: 635
i tested all infinity flash for this fon without succes just read flash in another phone and if u av furious pack 8 activeted use it or sent me imei and provider
The Following 2 Users Say Thank You to hippolyte85 For This Useful Post:
Old 02-12-2011, 19:46   #8 (permalink)
Member: 69250
Thanks Meter: 27
hi infinty team
i have one ot255x dead after unlock this the log:
==== [11/02/2011 09:02:24] ====
COM7 [VCP2] selected
module v3.72
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:4668:A00C
status: 01
Boot Done
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: F:\Program Files\InfinityBox\MModule\backup_security\id.1460B 94F.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_1D8B7F4C].rpl
New firmware found (v.3.72, database date: 13.01.2011):
TCL-ID detection...
device-id: 1460B94F
rom info ver: 05
project-id: MAUI.08A.W08.36.SP1.V34, 4C7F8B1D
version: 96E
provider: 255X-2ANRFR1
customization: CP96CP85
customization: XP96CP85
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
max address is too big, should be recalculated: 08BF8000->087C0670
file saved: F:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A__system_log_1460B94F_1D8B7F4C_20110211-090538.B0X.bin
Finished, time used: 2 min 53 sec.
the flash in support can't relife my phone and fixing bug for that model
thanks
Yours
Abdelouahab
[email protected]
Report Post
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-29-2011 11:26
HELP Dead 5130 v5.00 N.Schmetz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 03-08-2011 04:51
help! Dead 5110 v5.30 aklishin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-04-2001 11:56
nokia 5110 dead alpha Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2001 11:59
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
Page generated in 0.34071 seconds with 10 queries
