05-20-2017, 11:03 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: GREAT YAR*****
Member: 2495115 Status: Offline Thanks Meter: 34 | Alcatel Pixie 4 new version? I hChinese Miracle II [MTK module] v 1.56 Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 504E01FE35394A314B99124BC137DFA8 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , K59J1 [eMMC] : FLASH_CID : FE014E50314A39354B12994BA8DF93C1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000001D3000000 [eMMC] : FLASH_UCP : 7472 MiB [eMMC 8 GiB] DEV RID : 0xB3CD1776617D48CC5B9B801BC79CE34C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : SP Unlock [ v1.56 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 504E01FE35394A314B99124BC137DFA8 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , K59J1 [eMMC] : FLASH_CID : FE014E50314A39354B12994BA8DF93C1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000001D3000000 [eMMC] : FLASH_UCP : 7472 MiB [eMMC 8 GiB] DEV RID : 0xB3CD1776617D48CC5B9B801BC79CE34C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Fatal error, buffer empty! Phone connection lost??? Error while unlocking, somethig went wrong! Operation Failed Elapsed: 00:01:02 Reconnect Power/Cable! Operation : SP Unlock [ v1.56 ] Mode : Read Codes 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 504E01FE35394A314B99124BC137DFA8 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , K59J1 [eMMC] : FLASH_CID : FE014E50314A39354B12994BA8DF93C1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000001D3000000 [eMMC] : FLASH_UCP : 7472 MiB [eMMC 8 GiB] DEV RID : 0xB3CD1776617D48CC5B9B801BC79CE34C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Slot[1] SIMLock Info : [1] Level , [Locked] : True , [Count] : 10 , [Spc] : 768 , [UnlockCode] : 91235460 [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False Slot[2] SIMLock Info : [1] Level , [Locked] : True , [Count] : 10 , [Spc] : 768 , [UnlockCode] : 91235460 [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False ======== Info If phone not asking code : 1. Open MTK Setting Menu : *#*#3646633#*#* 2. GoTo : SimMELock->Network->Personalization->Unlock 3. Enter code If Code not accepted - use "SP Direct Unlock" mode Done! Elapsed: 00:00:32 Reconnect Power/Cable! ave previously unlocked several Pixies, usually mtk 6735. took one in this morning 6737! here are my logs: any ideas please ? Steve |
