03-13-2019, 13:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Alcatel POP 4s 5095k FRP Problem Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
03-13-2019, 17:15 | #2 (permalink) |
Junior Member Join Date: Feb 2019
Member: 2895574 Status: Offline Thanks Meter: 4 | you actually are running a version that seems old. there's CM2MTK2 V2.05 which supports the platform you're trying to terminate. i guess you may want to upgrade tool. i have mine already. Br |
The Following User Says Thank You to Infinitely J For This Useful Post: |
