Old 12-31-2008, 09:40   #1 (permalink)
limem2003's Avatar
Member: 108627
Thanks Meter: 307
Alcatel S107 flash done
COM1 [Serial0] selected
module v1.30
Device: Alcatel-S107
"advanced chip detection" active
Action: flash write
"smart write" active
Write: Firmware
Skip: Flex
Write: Language Pack
Write: FFS/File system
Skip: Images
Skip: Melody
Skip: Eeprom
Checking data, wait...
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-S107_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S107_eeprom_calibration-1_20081230-105736.80E.bin
Read data done
Check data ...
Check data done
Write ...
Area: Firmware
Write: Firmware
Area: Language Pack
Area: FFS/File system
Write done
Finished, time used: 234 sec
Remove/Install battery now !
The Following User Says Thank You to limem2003 For This Useful Post:
Old 12-31-2008, 09:48   #2 (permalink)
SOHAIL BASHARAT's Avatar
Member: 748880
Thanks Meter: 1,705
Goood infinty test report
thanks infinty team alwayes best...........
Old 12-31-2008, 16:26   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
module v1.30
Action: flash write
Write: Firmware
Skip: Flex
Skip: Images
Skip: Melody
Skip: Eeprom
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Area: Firmware
Write: Firmware
Area: Language Pack
Write done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Alcatel S120 Flash File not found in support [SOLVED] surin PolarBox 3 16 03-30-2010 10:57
alcatel ot-s107 flash files with italian language.. SicilianBoy Infinity-Box 2 07-04-2009 21:09
flashing alcatel ot-s107 flash files with italian language.. SicilianBoy Alcatel TCL Phones and New Models 1 07-03-2009 01:12
unlock alcatel s107 kopsa2005 Infinity-Box 28 09-08-2008 00:02
alcatel s107 permanently bloc sucesfuly unlock by infinity kopsa2005 Infinity-Box 8 06-24-2008 21:06
Page generated in 0.17700 seconds with 9 queries
