alcatel s210 dead after flash hello i have this issue after i flashed with: S210_firmware_U81C_105 + S210_lp_05O_804_En_Ro_It_De_Hu + S210_ffs_02 my phone is dead i tried all 3 firmwares from support but still dead after flashing with : S210X_firmware_lp_ffs_114_811_13O_604_De_Ru_Bg_Ua. 80M.bin it start but only for a couple of seconds. can i use fullflash readed from another phone to repair this one? regards |
Hi, If you have fullflash from other phone, pls send it to [email protected] and we will prepare good working flash files from that backup file. |
i have same problem, after flash is dead, pls help |
i suppose that fone restart try to rewrite same IMEI number i use this method on ALCATEL 211 WORK perferct |
ok, i will try....... |
post result if it good ok Br zemica Côte d'ivoire |
welcome bro that is gsm cooperation thanks to GSM *** looooooool Br zemica côte d'ivoire |
Here is 100% tested solution. 1. flash with this file : S210X_firmware_lp_ffs_114_811_13O_604_De_Ru_Bg_Ua. 80M.bin and tick firmware only by using Infinity box. 2. By using Furious box Rebuild security area and make sure you key in the actual imei at the back of the fone. 3.Wow !!!!!! its works 4. Press the Thanks button without spamming |
