03-30-2009, 17:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Alcatel S210x Big Problem ???? I tried to unlock this phone but was still locked and then flased with files from support.. Now phone keeps restarting, need help.... Infinity come to rescue... Here is the unlocking log : >>> COM4 [VCP1] selected module v1.32 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S210_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20090330-175108.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 65 sec Remove/Install battery now ! |
03-31-2009, 06:01 | #7 (permalink) |
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | After a lot of tries, at last I succeeded with the phone repair... Here is the process >>>> Flash phone with main and lp file.. Then in eeprom select appropriate FFS file and then flash it... After that repair imei.. Press the power on button for a longer time.. And all will be ok.. This the files I selected >>> S210_firmware_U81C_104 S210_lp_01O_801_En_Fr_De_It_Es S210_ffs_01 (eeprom) Phone fully repaired and unlocked.. >>>> SOLVED <<<< |
The Following 3 Users Say Thank You to zeel_zeel For This Useful Post: |
03-31-2009, 14:56 | #8 (permalink) | |
01-28-2010, 09:52 | #9 (permalink) |
Freak Poster Join Date: Jan 2001 Location: 13 00 N, 122 00 E (PH)
Member: 3156 Status: Offline Thanks Meter: 63 | updating this one and for newer versions, the above procedure does not work. before doing anything, backup FIRMWARE. flash with S210X_firmware_lp_ffs_114_811_13O_604_De_Ru_Bg_Ua. 80M.bin on support checking both firmware and ffs write IMEI afterwards. hold power on |
The Following User Says Thank You to d_bug For This Useful Post: |
10-11-2010, 09:43 | #10 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: Future
Member: 804247 Status: Offline Sonork: 1593659 Thanks Meter: 310 | Quote:
any idea? | |
Alcatel S210X Problem | ..::Angel::.. | Infinity-Box | 10 | 03-16-2009 18:02 |
alcatel ot-s210x unlock problem plz help | asif_ae | Multi-Box | 7 | 12-14-2008 11:25 |
Alcatel S520 Big problem help.... | karikari | Infinity-Box | 1 | 08-19-2008 16:23 |
alcatel 511 big problem | dimon | BF, BG, TH, BHx Series | 2 | 04-18-2003 12:09 |
Alcatel He1 BIG PROBLEM!!!! | Sher | Alcatel & TCL Old Models | 6 | 05-05-2002 14:12 |
