12-25-2008, 08:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | Alcatel s211 unlock done module v1.30 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S211_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20081224-224931.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 81 sec Remove/Install battery now ! THANKS INFINITY TEAM GOOD WORK BR YASERMALIK |
The Following User Says Thank You to yasermalik For This Useful Post: |
12-25-2008, 16:53 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
01-11-2009, 07:34 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
03-04-2009, 12:42 | #5 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | AGAIN UNLOCK DONE FROM UK ALCATEL S211 ORANGE UK COM4 [VCP0] selected module v1.32 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S211_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20090102-231436.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 88 sec Remove/Install battery now ! THANKS INFINITY TEAM BR YASERMALIK |
03-09-2009, 07:26 | #6 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | again s211 orange uk COM4 [VCP0] selected module v1.32 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S211_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20090308-232242.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 85 sec Remove/Install battery now ! br yasermalik |
infinity-alcatel s211 unlocking | hemsie | Infinity-Box | 9 | 11-12-2010 21:02 |
Alcatel S211 Unlock Success | Mr.3. | Infinity-Box | 15 | 02-01-2010 16:49 |
Alcatel-S211 unlock 100% okkkkkkkk | .::adnangsm::. | Infinity-Box | 1 | 06-25-2009 15:23 |
Alcatel-s211 unlock done | saqibmalik | Infinity-Box | 6 | 02-07-2009 16:03 |
Alcatel S211 Unlock Problem, please help | naveed7791 | Infinity-Box | 1 | 01-06-2009 10:45 |
