Old 01-27-2009, 09:55   #1 (permalink)
saqibmalik's Avatar
Member: 294880
Sonork: 100.1587133
Thanks Meter: 132
Alcatel-s211 unlock done
COM11 [VCP1] selected
module v1.30
Device: Alcatel-S211
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-S211_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20090127-144832.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 262 sec
Remove/Install battery now !
The Following User Says Thank You to saqibmalik For This Useful Post:
Old 01-27-2009, 12:49   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,453
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 01-27-2009, 15:17   #3 (permalink)
SOHAIL BASHARAT's Avatar
Member: 748880
Thanks Meter: 1,705
thanks br good work keep it up...........
Old 02-07-2009, 12:43   #4 (permalink)
abdulwajid147's Avatar
Member: 213172
Sonork: 1582799
Thanks Meter: 265
which cable u are using for unlock...???
Old 02-07-2009, 13:10   #5 (permalink)
Member: 213172
Sonork: 1582799
Thanks Meter: 265
i have found Pinouts and unlocked with infinty.........
posting Result.!
COM1 [Serial0] selected
Action: unlock
Boot...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection...
Set baud...
115200
Set baud done
Check hardware...
Check hardware done
Read data...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20090207-181244.80E.bin
Read data done
Check data...
Check data done
Writing...
Write: simlock
Writing done
Finished, time used: 1569 sec
The Following User Says Thank You to abdulwajid147 For This Useful Post:
Old 02-07-2009, 14:25   #6 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
use zte-7315 cable.
i tested many times
Old 02-07-2009, 15:03   #7 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
use zte-7315 cable.
i tested many times
infinity-alcatel s211 unlocking hemsie Infinity-Box 9 11-12-2010 20:02
Alcatel S211 Unlock Success Mr.3. Infinity-Box 15 02-01-2010 15:49
Alcatel-S211 unlock 100% okkkkkkkk .::adnangsm::. Infinity-Box 1 06-25-2009 15:23
Alcatel s211 unlock done yasermalik Infinity-Box 5 03-09-2009 07:26
Alcatel S211 Unlock Problem, please help naveed7791 Infinity-Box 1 01-06-2009 09:45
Page generated in 0.32174 seconds with 9 queries
