11-02-2009, 07:42 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1145301 Status: Offline Thanks Meter: 116 | Alcatel S319x after unlock no network whts the solution ? here is log for unlock baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:3E89:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) check... security area (code #1) fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20091102-114019.B0X.bin Area: Firmware flash: 98000300000001:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16GF32 done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20091102-120310.B0X.bin Finished, time used: 1406 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
11-02-2009, 08:23 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | What Is Correct Model In Ur Hand S319X/S319A Use Latest Module+Correct SimFree File Regards UMER |
The Following User Says Thank You to maplegsm For This Useful Post: |
11-02-2009, 09:41 | #4 (permalink) |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Just Go In Service Tab Put Orignal Imei And Press Write Br UMER |
11-02-2009, 10:48 | #5 (permalink) | |
If you can not find "imei" button in software here is an instruction: How to restore imei button: 1. Run Infinity-Box DongleManager: x:\Program Files\InfinityBox\DongleManager\DongleManager.exe 2. Press "Read dongle serial number (S/N)" button 3. Set "UK-Edition" option OFF (disabled) ! | |
Alcatel s211 after unlock no network | goldenploto | Infinity-Box | 5 | 08-18-2009 20:29 |
alcatel s621x after unlock no display | .::Zafar Communication::. | Infinity-Box | 10 | 05-27-2009 15:50 |
j700V after unlock no network after eeprom now blnks 18000004 | AnToS | UST Pro II | 6 | 11-14-2008 16:21 |
Ust pro 2, E250 after unlock No network & after eeprom No Speaker! | Wais777 | UST Pro II | 7 | 04-09-2008 23:55 |
Bosch 909s after unlock no network | Bigbrothers2000 | Various | 2 | 04-18-2001 17:10 |
