Old 02-13-2009, 08:40   #1 (permalink)
gurinder's Avatar
Member: 167191
Thanks Meter: 358
alcatel s319x unlock problem
i have problem with this firmware of alcatel s319x. i flashed it with unlock file. but i forgot to take ts backup.. but i have its eeprom backup and that eerpom backup is saying RENGE CHECK error when i tried to back flash it into handset.
now problem is that handset is Ok.. sound is ok but screen is black after flashing with unlock file-
handset has previous version and here is the log of handsets previous version:
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 detection finished
identification#1 protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size: 00C00000/00400000
detect device identification#2...
anyhelp in this case or anybody have its original file backup to get my handset back
gurinder
Old 02-13-2009, 12:14   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,298
Hello,
Did you tried to flash phone with other firmware from support area ?
Old 02-13-2009, 18:18   #3 (permalink)
gurinder's Avatar
Member: 167191
Thanks Meter: 358
there are only 2 other firmware except that simfree firmware... now in flashing with other firmwares.. do i need to tick FFS format????
Old 02-13-2009, 19:53   #4 (permalink)
Member: 130995
Hello,
Yes, it's better to make "ffs format" box checked to reset phone settings to default values during flash process.
Old 02-14-2009, 09:56   #5 (permalink)
Member: 304933
Sonork: 100.1618191
Thanks Meter: 49
full flashed and with eeprom file from support site
but set still in lock mode also ffs with flashing
any help
i flash two set but set in lock mode
ple help infinity box
Old 02-14-2009, 11:44   #6 (permalink)
gurinder's Avatar
Member: 167191
Thanks Meter: 358
i tried each and every file on support.. all simfree files on support.. but my handset not unlocked... then as i told about my problem that i got blank screen after flash with simfree files..is revived by flashing with S319X-2GPWGB1_XH16DP32_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_Orange-Uk.B0M.bin
now i have successfully revived my handset but handset is still locked..
plz... do something for this handset...
Old 02-14-2009, 12:49   #7 (permalink)
Member: 130995
Hello,
Try to flash your locked phone with this file now:
http://www.infinity-box.com/download...imfree.B0M.bin
Waiting for your results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 02-14-2009, 21:58   #8 (permalink)
gurinder's Avatar
Member: 167191
Thanks Meter: 358
is it from support area ???? if yes then it will definately not work.. if it is else then may be work for me
Old 02-14-2009, 22:09   #9 (permalink)
Member: 130995
Hello,
Special file was prepared for your phone: alcatel s319x unlock problem
If your phone flashed now with good locked firmware and has no problems with LCD make this:
1. download file by given link
2. flash phone with downloaded file (make "format ffs" box checked during flash)
3. try to power on phone and see results
in case of any problems post here operation log text for flash write operation
Old 02-16-2009, 10:59   #10 (permalink)
gurinder's Avatar
Member: 167191
Thanks Meter: 358
COM1 [VCP0] selected
module v2.64
Device: Alcatel-S319X, S319A
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:1CDB:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
230400
Set baud Done
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090216-150616.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CH16JB10
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
use default security area (code #3, part #1) pattern
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090216-151226.B0X.bin
Finished, time used: 391 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On
thnx to infinity team, handset unlocked with this file.. but now problem is language.. language is changed and more problem.. this handset has middle button for selecting purpose called OK. now this OK button opens the menu but not selecting or futher opens the submenu..
example. phone has total 9 menu. so for selection 9th menu.. in this firmware i have to press 9 button from keyboard then submenu will open other wise by pressing OK button on 9th menu.. menu not appearing.. do u understand what i want to say sir... for opening a particular menu.. we have to press that particular similar button on keypad to open that menu.
thnx for cooperation to unlock this model but plz.. see about language option and that of also menu openin option.
gurinder
Old 02-16-2009, 11:03   #11 (permalink)
Member: 130995
Hello,
Thanks for test report, we will try to check what may be wrong and try as soon as possible, need some time to think.
Old 02-16-2009, 11:03   #12 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
for language pls try to goto settings and make your luck maybe youll get lucky and change language to english...or you can try *#0044# then try to check in settings also bout your problem with the middle button....post result
Old 02-16-2009, 11:09   #13 (permalink)
gurinder's Avatar
Member: 167191
Thanks Meter: 358
thnx
thnx to alfox sir for language code but menu problem same intact.. after goig to setting option.. further menu not opening by pressing relative button..
how about that problem??
gurinder
Old 02-16-2009, 11:37   #14 (permalink)
Member: 130995
Hello,
New customization files is ready, please try to flash it one by one and let's see results.
Do not forget to make "format ffs" after flashing (or make "format ffs" box checked during flash process).
1. http://www.infinity-box.com/download...imfree.B0M.bin
2. http://www.infinity-box.com/download...imfree.B0M.bin
Old 02-16-2009, 12:04   #15 (permalink)
gurinder's Avatar
Member: 167191
Thanks Meter: 358
menu problem same intact with these files but ok button appears on wap setting options at left upper button..
are these files only customization?????
may be that menu have no further sub menu bcoz these files as u wrote are customize.. this is my guess... correct me if i m wrong... may i try again with other files.
may be this type of behaviour of handset is by default....
gurinder
Pls help with alcatel s319x unlock TALIAT Infinity-Box 3 08-02-2009 15:12
Alcatel S319X unlock done but no service kemot Infinity-Box 4 06-20-2009 08:37
Alcatel s319x unlock ok but help Lutfur Infinity-Box 0 04-22-2009 10:29
alcatel s319x unlock problem zeeshan tayyab Infinity-Box 4 03-26-2009 08:46
Alcatel S319x unlocked in one pass jepetu Infinity-Box 2 03-23-2009 13:59
Page generated in 0.44941 seconds with 8 queries
